Old 07-09-2017, 08:34 AM   #1
1982 31' Excella
Norwalk , Iowa
What gauge wire for parallel setup?
HI, I'm a new owner of a 1982 Excella 31'. My AS has 2 battery boxes separated by about 4 feet with the fuse box between them. Currently each positive and negative battery cable ties into the fuse box. I want to rewire the batteries to proper parallel setup.
This will require that I add 2 new cables about 4-6 feet long. One two bridge the positive terminals and one for the negative terminals. Maybe even longer in order to make it neat.
My question is what gauge battery cable should I get for this job? The writing I can see on the current wires is “G-9-R” on the red wire. Don't know what that means.
I have 2 AGM 27 92 amp hour batteries and a Boondocker 60 amp charger Converter.
Hope to get this done this week as our first outing in our new baby is this weekend. Any/all help is appreciated.
MagicMarty is offline   Reply With Quote
Old 07-09-2017, 08:47 AM   #2
Newport Beach , California
Wire sizing
A good site for info on wire size would be Blue Sea, they have a chart available for length and current for correct wire size, along with other misc electrical ideas.
hotfoot
hotfoot88 is offline   Reply With Quote
Old 07-09-2017, 09:23 AM   #3
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
I was very surprised to see that the batteries in a friend's 2015 were cabled with what appeared to be #10 AWG from the factory.
I have a 2009 where the battery cabling was redone and routed thru a marine battery disconnect switch. Gauge is #6 AWG between batteries and between disconnect switch and 12 volt fuse panel.
You could have one battery removed, leaving the remaining battery to handle all loads. In my 2009 the 12 volt fuse panel is rated at 85 amps, so from a circuit design perspective #6, rated at 95 amps, would be specified.
If the trailer will always be powered by two batteries sharing the load, #10, rated at 52 amps, is adequate between batteries, but not between the batteries and fuse panel.
Personally, I'd go with #6 if I were to go new.
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 07-09-2017, 10:04 AM   #4
1982 31' Excella
Norwalk , Iowa
Is there any problem with using the wire from a 4 or 6 AGW jumper cable to run between the batteries. Of course I would cut off the clamps and attach new connectors. Or is it better to get bulk wire, but that seems really expensive?
Old 07-09-2017, 01:27 PM   #5
CruizinDux's Avatar
Tracktown USA , Oregon
Here are a couple of threads I have saved with posts from Lewster.
Posts 5 & 9
http://www.airforums.com/forums/f449...ed-154343.html
Post 23
http://www.airforums.com/forums/f449...-132157-2.html
As you can see in the image I opted for the 2/0 for the connectors. I'm not an electrician so I'm not sure if this is applicable to the 4-6' run. I also attached the before connection.
Maybe Lewster will check in?
Name:	IMG_9261 (Small).JPG
ID:	289052   Click image for larger version
Name:	Batt box (1) (Small).JPG
CruizinDux is offline   Reply With Quote
Old 07-09-2017, 01:48 PM   #6
Zil
Curtis Wright
Eyren Haven , South Jersey
If each battery's positive terminal connects to the positive terminal on the same fuse block, the same with the negative to negative. Your batteries are already connected in parallel. What do you want to accomplish with another set of cables?
Zil is offline   Reply With Quote
Old 07-09-2017, 02:56 PM   #7
Box Elder (formerly of Center Moriches, NY) , South Dakota
A welding shop can fabricate heavy cables for you. Generally, the heavier, the better.
NY24 is offline   Reply With Quote
Old 07-09-2017, 03:15 PM   #8
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Posts 5 & 9
Post 23
I see that the orientation of your batteries is the same as what I received from the factory. Meaning, that You will have to remove a number of cables to gain access to the top fluid caps to check the water.
Following a previous post from 'someone', I turned that battery around, used the same jumpers to re-attach them, and now I can open the caps to check the fluids, no problem.Click image for larger version
Name:	Ship's batteries as recieved.jpg
Name:	Ship's batteroes after switching.jpg
MelGoddard is offline   Reply With Quote
Old 07-09-2017, 04:00 PM   #9
1982 31' Excella
Norwalk , Iowa
Right now my circuit goes in and out of both bateries at the same time. Is it not better for the circuit to go in one battery and out the other?
Old 07-09-2017, 04:49 PM   #10
CruizinDux's Avatar
Following a previous post from 'someone', I turned that battery around, used the same jumpers to re-attach them, and now I can open the caps to check the fluids, no problem.Attachment 289055 before
Attachment 289056after
Hey Mel, thanks for the reminder. I thought I had saved the above thread but could not locate it. Maybe they'll see this thread and jump in. This time I'll save the thread.
I agree, this is a great approach....duh, can't see the forest for the trees
I had thought about it but since I had already just converted to the 2/0, figured I'd wait till the grp 24 head south and maybe I'll convert to the 2X6's.
Also for us since we have no SP at storage, if I'm not using the TT in a few weeks I bring them home for a spot on my bench where I can kep a close eye on them and add a trickle charge and h20 top of as needed. My current setup is an easy disconnect/connect. Looking at this image (that I believe is from that thread) it's a bit of a birds nest.
Happy Trails
p.s I've read from lewster that it's best to have a the pos connect at one bat and the neg at the other batt
http://www.airforums.com/forums/f449...-154343-2.html Post 18
p.s.s I like the cable wraps. Great idea.
Old 07-09-2017, 05:20 PM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you want to have fun with wires, play away. 10/0 could be better than 6/0 you never know when 0.0001V at 2,000 A might matter.
Your converter / charger is likely putting < 50A into the batteries (25A each). A 1KW inverter will pull about 80A (40A each). On a typical setup, the inverter is more of a load than anything else. With 92 AH batteries, anything over about 90A per battery is a bit silly.
Unless you are doing something really weird, once you get to about number 6 (a very different thing than 6/0) you hit diminishing returns. A 12KW inverter would classify as "something weird". Forty feet of wire to the batteries would also be in the same category.
What are your goals here? If it's just "make it right", hooking both batteries to the same block is fine.
Old 07-09-2017, 05:43 PM   #12
waninae39's Avatar
2017 22' Sport
NCR , Ontario
here are the wire gauge charts
Name:	wire gauge chart.jpg
ID:	289075   Click image for larger version
waninae39 is offline   Reply With Quote
Old 07-09-2017, 07:43 PM   #13
2011 23' FB Flying Cloud
2008 19' Safari SE
Brossard , Quebec
Additional battery
My question is what gauge battery cable should I get for this job? The writing I can see on the current wires is ďG-9-RĒ on the red wire. Don't know what that means.
I add a 100 Ah additional portable battery (in a case) with a 7 feet cable for occasional boondocking with AWG #2 cable with Anderson 175 Ah connectors. No electrical loss, flexible welding cable.
In a such case, I change the battery capacity "connected" in my Victron BMV-700 accordingly.
I install an additional portable 90 Watt solar panel (small 35 Amp. Anderson connector right hand side on the picture) over the existing 95 watt roof top of my 23 feet Flying Cloud.
With this set up, no generator needed, batteries are nearly always full.
The 600 watt inverter (with a 15 Amp. transfer switch) is used to enjoy watching TV, charge computers and I-Pad and even a hair dryer switched to 220 Volts (delivering 320 watt) for my wife...
See pictures of my cabling set up below.
Michel
ID:	289089   Click image for larger version
Papou is offline   Reply With Quote
Old 07-09-2017, 08:11 PM   #14
1982 31' Excella
Norwalk , Iowa
Hi
Thanks Uncle Bob,
I surely don't want to add a ton of wire if I don't have to. I am trying to make this simple as possible.
One goal is to install a battery monitor to the system. In order to do this I need to install the shunt to the negative cable before the fuse box. Can I connect both negative cables to one side of the shunt and then just run one wire from the shunt to the fuse box?
This would eliminate having one 50 amp fuse on each battery and change it to both batteries being on one 50 amp fuse. Is that going to be a problem?
Is there any logic in splitting it up and running two wires from the shunt to the fuse box? That would bring a negative to both locations on the fuse block but seems to me that all that does is put 2 fuses the same circuit.
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 09:18 PM
Honda Pair With 30 amp Parallel Setup Cracker Generators & Solar Power 11 04-24-2008 01:19 PM
Proper gauge of wire? 65 overlander Electrical - Systems, Generators, Batteries & Solar 8 01-22-2006 11:20 PM
What size breaker for 8 gauge wire? guy99 Electrical - Systems, Generators, Batteries & Solar 7 11-20-2005 01:24 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
