Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-18-2009, 10:06 AM   #1
Bea
1972 23' Safari
Weyers Cave , Virginia
What can I expect my electric bill to be?
Hello all,
I have a friend who wants to hook up her 1970's vintage Airstream on my property, and into my home electicity, for a few months. She is semi-disabled and thus will be in the trailer most of every day (ie. using lights, heat, etc.)
So, I am hoping you experienced folks can give me some idea of the ballpark figure for an electric bill of a trailer being used as a residence.
I really want to help her out, but I need to know if I'll be able to afford the bump in my utility bill.
Thanks in advance for any insight you can provide!
Bea is offline   Reply With Quote
Old 11-18-2009, 10:57 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
For just lights and a TV/radio, I doubt you’d notice a big difference in your electric bill. Think of it as just another bedroom.
But, how is she going to heat the trailer?
If she uses electric space heaters, or a heat pump, then you’ll notice a difference. How much? That depends a lot on how warm she likes it, how cold it gets, and your electric rates. I’d plan on a few bucks a day for electric heat. Maybe upwards of $5 per day for cold snaps as a rough estimate until you get the first bill and know for sure.
If she’s going to use propane and the AS furnace, then she’ll be filling up the propane tanks on a pretty regular basis. Does she have 30 or 40 lb tanks? Who’s going to fill them and pay for them?
When we have visitors stay for Thanksgiving weekend in our SOB trailer in the past, we would go though both 30 lb tanks in 5 days, and that was strictly for heat. Of course, it’s typically a bit colder here than Virginia.
btw - I think you're a saint for letting her stay in her trailer at your house!
Good luck!
Chris
Old 11-18-2009, 11:07 AM   #3
2019 28' International
Leonardtown , Maryland
If she uses her refrigerator and hot water heater that will make a difference as well. Those two items in a month will be about $10 to $20.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 11-18-2009, 11:20 AM   #4
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
In it all the time...my guess...$100 plus per mo.
Those space heaters can use the juice. Maybe
$140.00 plus during the winter. Then there is propane,
water, sewer and trash. Help is help! And
Free aint free. Keep an eye on it...it won't take long
to figure it out.
kennethowens is offline   Reply With Quote
Old 11-18-2009, 11:21 AM   #5
Bea
1972 23' Safari
SO glad to be getting some responses. I was worried I might have put this in the wrong place (didn't realize there was a "Fulltiming" forum... got here from a Google search.)
Thanks so much for your replies so far!
Old 11-18-2009, 11:50 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Bea,
How about water and sewer? Do you have provisions for those? Also, it gets cold enough in the Valley to have to worry about freezing; will you be able to wrap the "basement" and keep the area somewhat heated?
Pat
pmclemore is offline   Reply With Quote
Old 11-18-2009, 12:05 PM   #7
Bea
1972 23' Safari
Originally Posted by pmclemore View Post
Bea,
Pat
I think the plan will be for her to use the facilities indoors. Thanks for the tip on insulating. I'll have to look into that.
Old 11-18-2009, 02:04 PM   #8
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
a (very) little math, here
okay, assume she uses ALL of the 30amp 120vac power available. And assume your electricity costs .0765/kilowatt hour; then 24 hours/day x 30 days/mo x 30amps x 120v x .0765 divided by 1000. this would equal $198/mo!!!! but of course, her actual daily usage would be less than 12 hours, which cuts it into half $100/mo, and she absolutely will NOT use 30 amps of power, probably less than half that = $50/mo. This, to me would be a MAX figure. of course, the utility rate may be more or less (I dunno), so you may have to adjust. But I would bet that it will be less than $50/mo. Way to go helping out!
ol bill
wmarsha is offline   Reply With Quote
Old 11-18-2009, 02:34 PM   #9
Bea
1972 23' Safari
ol bill
Thanks for helping with the math factor. I was able to look at past bills and calculate a KWH rate (with taxes,etc.) of 0.108-- now I'm off to plug that into your VERY helpful formula. Thanks!
Old 11-18-2009, 02:40 PM   #10
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Bea and welcome, This link may help the heat bill. http://www.airforums.com/forums/f462...eam-20597.html. Bails of straw would work in a pinch but critters will like it too.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-18-2009, 02:49 PM   #11
Bea
1972 23' Safari
Very helpful. Will probably go with this instead of the bales of straw idea... not looking for any ADDITIONAL tenants this winter.
Old 11-18-2009, 03:09 PM   #12
Minno's Avatar
1972 31' Sovereign
Hi Bea,
When you do the math for figuring out electrical usage, keep in mind that the trailer needs to be heated 24 hours a day. Granted, you can drop the temp down when she's not in there, but you can't shut it all the way off. Even if you don't need to worry about water freezing, you really don't want to start heating the trailer up from near freezing or below freezing temps evey time she wants to go out there for the night.
Do you have a 30 amp 110 VAC outlet for her to plug into?
Chris
Old 11-18-2009, 03:23 PM   #13
_
hi bea...
IF electricity use is CONFINED to charging the batteries and using the 12v interior lights...
the monthly charge will be small (20$ or so depending on KW rates)
but HEATING water or the trailer involves 1500 W or larger appliances...
and EACH of those will bump the juice bill significantly.
there is ALSO the issue of wiring.
because IF you don't have a dedicated 30 amp outlet (and correctly sized wires)
there is RISK of damage, melting and so on with 2 or more 1500w appliances 30-100 feet away on an extension cord...
______________
so ideally you would supply enough electric power for the interior lights and battery charging...
then USE LPGAS for heating water, cooking, the fridge and HEATING the trailer.
this could mean regularly filling the rv bottles OR having a LARGE lp tank set up and filled by a gas vendor.
IF the lp gas use if fully incorporated the cost of electric power (and wiring install) will be MUCH MUCH less.
cheers
2air'
Old 11-18-2009, 03:36 PM   #14
I wished I lived in an area with $.0765/kilowatt-hour electrical rates!!!!
Here in Silicon Valley my baseline rate is $.11531/kW-hr. Check your local rates before you take that plunge. Also, electric heaters can be pricey!! I left a 1500W oil filled electric radiant heater running non-stop in my bedroom for about a month (turning the thermostat down during the day when I was at work). This took my electrical usage well above my baselines and my rates skyrocketed. I was graced with a $250 electric bill that month.
That actually brings up a good point. If you have a tiered billing system like we do here in California with PG&E then your electric bill could really go up with her added usage. Not trying to scare you away from the idea of helping out a friend, but rather hoping that you will fully consider all added costs.
toddster is offline   Reply With Quote
Old 11-18-2009, 03:57 PM   #15
Bea
1972 23' Safari
Based on my look back over past bills, I DO think I pay 'tiered' rates, so I'd better find out where the next tier kicks in.
So glad I found this forum. I had tried calling the manufacturer and dealers and none of them could even BEGIN to offer me any kind of info. You guys are the best!
Old 11-18-2009, 05:25 PM   #16
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
My cost .0861
We pay $.0861/kilowatt hour.Our current bill is $45. It started out at $35 last Feb 2009 when we settled down for a while. It went as high as $75 this summer as A/C use was needed. Avg high temp in summer is high 90's. Avg low temps for winter is 30's.
This is for our AS MH which has a 30 amp plug. We don't use any electric heaters. We have a small 19" LCD TV. Use a 20 light string of Christmas lights in a wine bottle for a nite lite. We use microwave maybe 5 minutes a day. Toaster in morning. Fridge is set to 120 volt ac. All other heat & cooking is with propane.
Maybe you can insist no elect. heater be used. Does tenant have a elect water heater? Hope this info helps you in your situation.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 11-18-2009, 05:29 PM   #17
Retired.
. , At Large
When we lived in our Sovereign, our electric bill was never over $105, and we were paying a premium to the RV park. Regular rates would have been on the order of $70 a month, tops.
Old 11-18-2009, 07:36 PM   #18
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I Don't know - seems easier to wait until you get the first bill. You know what you normally use and anything above that is the TT. Could be wrong - not the first time and definately won't be the last.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 11-18-2009, 07:56 PM   #19
richinny's Avatar
2011 34' Classic
bea,
you might try asking at a year round rv park that is near you if they are metered. they would be the best example of rates and usage in the winter.
to protect yourself, you can tell her what your limit is on support for the electric. it will encourage her to conserve when possible and not take you to the poor house.
you're nice to offer this help :-)
Ricky
Old 11-18-2009, 08:12 PM   #20
Central , Mississippi
We just had this conversation with a full-time couple who are camped nest to us here in Fort Wilderness. Their peak bill was $140 during the Texas summer when running both Airconditioners in a MONSTER 5th wheel.
Some other friends who full time in MS with a large 5er in a shaded area never had a bill over $100 on metered service 12 months straight.
Our dual air SOB at the weekend place averages $20/mo for heavy useage 2-3 weekends a Month. Winter electric heating is similar to summer cooling in our area.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
electricity, power
I don't expect the answer I want... ltenbrink Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 11-13-2009 03:56 PM
What to expect for $3K PoconoAir 1956 - 1965 Caravel 92 09-20-2007 06:37 PM
What can I expect? E Double General Repair Forum 5 08-28-2003 10:17 PM
First Ralley, what to take/expect Stefrobrts WBCCI Rallies & Events 11 05-04-2003 05:21 PM
what to expect? Chas Airstream Trailer Forums 20 01-18-2003 02:19 PM
