Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-21-2006, 01:04 PM   #1
dragonnfly
Profile:  1972 27' Overlander
Weston , Ohio
Images: 11
What is this...can it be bad??
Hello, we have a 1972 Overlander that kind of fell in to our hands. We are figuring out why they gave it away. We really want to get it going and be able to take the kids camping in it before they get too old and refuse to go with us. We have done a lot of camping with the old pop up but this should be so much cooler. Anyways, back to what Im here for, we have some wiring issues. Can anyone tell me what this is and could it be bad?? It says "Safety Device" on it but what is it protecting. It is in the front of the camper with the 7-way trailer lighting access. We are having some lighting issues and not sure if this could be the cause. Is this something the PO added, or is it original?? I have always loved airstreams and when our middle child is off to college, my husband and the baby (hes 11 now) intend on doing a full restoration. This site has already been very useful and Im sure it will several more times. Thank You Melanie
dragonnfly is offline   Reply With Quote
Old 05-21-2006, 01:08 PM   #2
nickcrowhurst
Profile:
It looks to me like a thermal cut-out. If the circuit draws excessive current for safe operation, the cut-out heats up and the circuit is broken. When it cools down, the device will reset.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 05-21-2006, 01:16 PM   #3
Safari64
Safari64's Avatar
Profile:  1964 22' Safari
Eagle River , Alaska
Yep, looks like a thermal circuit breaker.
My 64 has one near the front on the main line to the light circuit (tail/brake/turn) and another on the electric brake circuit.
It WAS the cause of my light problems.
They are cheap, easily replacable. NAPA, RV shops.
with volt/ohm meter check for continuity between the poles, if none, replace it. Either way, clean the contacts.
Safari64 is offline   Reply With Quote
Old 05-21-2006, 01:21 PM   #4
klevan
klevan's Avatar
Profile:  Albuquerque , New Mexico
Definitely a thermal breaker. I would reroute the red wires and feed them both from the top to eliminate that kink and possible rubbing against the bracket. Disclaimer: I often create more problems because I never leave well enough alone.
Ken Levan
2005 Chevy 2500 HD Duramax/Allison
Formerly WBCCI #8654
klevan is offline   Reply With Quote
Old 05-21-2006, 01:46 PM   #5
dragonnfly
Weston , Ohio
Images: 11
If this was bad thought would none of my lights work? Or just a few of the outside trailer lights not work? We have a right brake light ( I think the left is too rusted) , back up lights and thats it. No clearance lights or running lights. Thank You very much for your help. Melanie
Old 05-21-2006, 04:42 PM   #6
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Malanie, if one brake light works, that circuit breaker is not why the other doesn't.
Since you said you have a pop-up, I am guessing you already have the wires connected correctly and working on your tow vehicle. Now, what I have found is that Airstreams of the vintage you have, are wired differently in the plug to the tow vehicle than what is currently industry standard. When we got our Argosy, it was wired the same way you describe, with the same problem. We had one brake light, and a backup light, and that was it. I re-wired the trailer pigtail to match our tow vehicle, and then went around the trailer making sure the lights were well-grounded. I had to drill out several rivets holding the fixtures to the coach, as they ground to complete the circuit through the rivets holding them on.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 05-21-2006, 07:32 PM   #7
dragonnfly
Weston , Ohio
Images: 11
Hello again, OK all this experimenting will have to wait for next weekend, but the hubby kept saying that was the problem and I argued. He believed with me after we found a anmeter wire off the univolt and thats when the couple lights came on. I guess we will have to sit with the test light and figure out where all the wires go on the old trailer plug. As for replacement clearance lights I found those at Wal-mart (I had read that in a post). Any hint for the 1972 houseing for the brake lights and back up lights? I have seen a lot on here but its usually the older trailers they are refering too. Thank You Melanie
Old 05-21-2006, 08:24 PM   #8
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Melanie,
If that blue wire is connnected to your trailer brakes at any point, then that device should be an auto-reset circuit breaker. This is used on the brake circuit to ensure that a pulse of DC will reach the brakes if the circuit shorts or fails and will provide the trailer some braking power in an emergency situation.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 05-21-2006, 09:50 PM   #9
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
1972 Airstream Bargman Connector Wiring Diagram
Greetings Melanie!
Many of us have encountered the Airstream/Argosy Bargman connector wiring schematic that doesn't mate to the modern standard on our tow vehicles. The diagram found at the location linked below might help in identifying the functions of the wires in your coach's connector:
http://www.airstream.com/airstream/p...lug1966-81.pdf
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 05-22-2006, 05:19 AM   #10
overlander63
Images: 58
Thanks, Kevin. I can never find that diagram to upload when I need it.
Here is the current one, so you can make the needed changes:
#Color Circuit
Functionconnector interior
1white common ground
2blue electric brake
3green tail/running lights
4black battery charge (+)
5red left turn/stop
6brown right turn/stop
7yellow auxiliary/back upNOTE: #7 is the center terminal and currently is most commonly used for backup lights
AIR#2611
Old 05-28-2006, 02:38 PM   #11
Mrcrowley
Profile:  1977 31' Sovereign
Manchester , New Hampshire
#Color Circuit
5red left turn/stop
I found the best way to find the correct wires for trailer and for vehicle are to make a light tester with alligator clips put one end to ground other to the poles do the left blinker then right the parking lights the brakes write down the color of the wires and the position of the poles. Then use one fo your deep cycle batterys and run a the positive light to the trailers connection then go to back of trailer and see which lights light up the outlights are usually the running lights they run the marker lights to,the next set is the back up lights the next set is the brake and the blinker lights . blue wire is universal for trailer brake functions.
Mrcrowley is offline   Reply With Quote
Old 05-28-2006, 02:41 PM   #12
Mrcrowley
Originally Posted by lewster
Melanie,
Oh wow didnt think of that one so this circuit breaker would give power to brakes if circuit fails is that what your saying is this common on most trailers with electric brakes?
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
Sex offender gives bad name to AS's NewStreamer Our Community 18 01-11-2003 10:25 AM
The good and bad TRAPEZE Airstream Motorhome Forums 1 01-01-2003 06:21 AM
service... canny_banjo_man Airstream Motorhome Forums 6 11-12-2002 05:52 PM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
