Old 07-30-2013, 08:01 PM   #1
matthorr's Avatar
2012 25' FB International
Annapolis , Maryland
What are these wires?
I was replacing my outside shower with the new stainless version and noticed a pair of wires to nowhere (pic attached) - one white and one purple with a yellow stripe. They had crimp connectors on the end. I only got millivolts on the voltmeter but didn't try every switch.
Amy idea what they are? Should they be connected to something? I was hoping the were a 12V supply so I could use then to add a fan to the bedroom. They were right behind the inside shower running along the bedroom heat vent line.
TIA
matthorr is offline   Reply With Quote
Old 07-30-2013, 09:40 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Why not call JC and ask the experts.
Toll Free Technical Support Line
1-877-596-6505 This is a voice mail system only. Your call will be returned within 24 hrs. After listening to a brief greeting, please record the following information:
  • Your name
  • Telephone number
  • Specify trailer or motorhome
  • Model year
  • Last six digits of the Airstream serial number
  • Brief description of problem or information need
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 07-30-2013, 09:44 PM   #3
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
You should have a wiring diagram in your manual. You might check that too.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-17-2013, 03:59 PM   #4
matthorr's Avatar
I couldn't find a wiring diagram in the manual, but after some investigation with a volt meter, the mystery has been solved.
They are wired into the circuit controlled by the switch for the lights in the forward overhead storage cabinet. They must reuse wiring harnesses for various configurations.
The good news is I was looking for a ground wire to install a wall-mounted fan in the bedroom and this one will work well.
