Originally Posted by krowsea
Thanks for the info, I thought there would be some type of structural support behind the screw. My question though is, can I attach the other ground connections in the same manner, or is there another preferred location?
Thanks!
John
IMHO you should not use the same ground point for both grounds. I supopose the question is "why two grounds?".
Scenario 1. If the second is a "backup" of the first in case the first should fail in some way, then you should use a completly different location for the second. I should think that grounding it in a similar manner would be fine, just seperate the two grounds by some distance.
Scenario 2. If one of these grounds is dedicated to the shell as in the way my Univolt is set up, then there is the possibility that the other ground is there for some completely different purpose (that I am not able to determine).
What you might try doing is posting here the model number/etc of your Intelli-power and posing the question again. Lots of folks on the Forum use them so if this thread stays alive for a few days, somebody will have the answer, because they will have dealt with it before. There's even a member of this forum who has a distributorship for this brand, but I can't rememeber who.
Any Rivet Masters got the answer?
