Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-29-2018, 11:54 AM   #1
1995 21' Sovereign
Petaluma , California
Weird question, what causes wires to spark when connected to 12v?
ok, title not exactly accurate but hard to describe.
I've been working on/testing my 12v wiring for my 7 way plug for a while now and noticed that certain wires will spark when I put 12v of power on them using a jumper (not when powered from the TV). I'm just connecting a wire straight from a 12v source inside trailer to the wire where it comes into the trailer from the umbilical plug.
The wires that spark are the running lights, brakes, reverse. The ones that don't spark are the left and right brake lights/blinkers. It seems the ones that spark are the circuits that split off to multiple locations vs just going to one side..
It's not a crazy spark, just when I initially hit it with 12v it sparks, or if the alligator clip isn't secure, it might spark a little.. it does not spark when connected to the TV.
I just want to verify nothing weird is going on! thanks for the help
cgseanp is offline   Reply With Quote
Old 06-29-2018, 12:31 PM   #2
Mollysdad's Avatar
A spark or arc is an indication that current is flowing.
WHY it's flowing is another question.
You can get lights to light by jumping certain wires in the 7-way.
Old 06-29-2018, 12:32 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The ones that are drawing more current. One really small signal light may not draw enough to see the spark. Multiple outline lights might.
12v
weird weird weird. 12v goes dark. click. wulfraat Batteries, Univolts, Converters & Inverters 8 10-10-2016 01:14 AM
Root causes and cures Boondocker Towing, Tow Vehicles & Hitches 18 10-30-2007 06:29 AM
What causes rear sag on some airstreams? durans54 Repairing/Replacing Floor &/or Frame 4 12-02-2006 08:25 PM
Burning Spark Plug Wires geodude1958 Mechanics Corner - Engines, Transmission & More... 10 07-10-2005 07:58 PM
Washing causes problem with 1971 overlander happier Cleaning, Stripping & Polishing 13 06-28-2004 09:50 PM
