Old 08-30-2011, 08:57 PM   #1
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Weird low voltage problem
Just getting ready to leave tomorrow morning for a 3 day trip and of course, a little problem shows up. I have a 2009 27' FB Flying Cloud. The interior lights are all dim and the status panel flashes a problem with the battery. The batteries are both freshly charged and reading 13.7 volts. When I plug into AC, everything looks good. I haven't had a chance to dig in with my meter yet, but any thoughts out there would be appreciated. Thanks, in advance. Hal
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 08-30-2011, 09:06 PM   #2
dznf0g's Avatar
Oswego , Illinois
If the batts truly read 13.7V after a few minutes of being disconnected from shore power, I'd be surprised. Sounds like a reading while hooked to the inverter. (shore power). Most likely 12.7V or so, if the batts are healthy. Unplug with your voltmeter hooked to the batts and watch for an hour or so with a smallish load on them. I'd bet you'll see the voltage drop to below 12V rather quickly, indicating a battery problem.
Old 08-30-2011, 09:34 PM   #3
Southwestern , Ohio
I second the previous post--13.7 V sounds like the voltage while charging. If your lights are dim the 12 V bus voltage is low, period.
This problem could be caused by a poor (loose or corroded) battery connection. Charger would think the battery is charged because charging voltage would be in the right range, but when you try to draw current out of the battery the bus voltage drops because of the resistance of the battery connection.
Nuvite-F is offline   Reply With Quote
Old 08-30-2011, 09:47 PM   #4
dznf0g's Avatar
Oswego , Illinois
Yup, that too. In addition to checking the battery post connections, put a screw driver on all the connections at the positive buss and the negative buss. I found some rather loose from the factory.
Old 08-31-2011, 12:35 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, My batteries last about three years and have been replaced twice now. looks like your trailer could be about three years old. [depending on production date, not sale date]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-31-2011, 06:19 AM   #6
Bandits's Avatar
2008 30' Classic
Get a hydrometer and check each cell in each battery. I have found voltage checks, as well as load testing to be useless in attempting to determine the charge state of the deep cycle batteries most commonly used in travel trailers.
Jerry, Irene & Clancy
Bandits is offline   Reply With Quote
Old 09-01-2011, 09:20 AM   #7
Portland , Oregon
Thanks for all your input. I've been working on cars all my adult life and I should have figured this out sooner. The Interstate batteries that came with the AS were dated June of 2009. I just didn't expect deep cycle batteries to go bad so soon. The two batteries would take the charge and looked good when I tested the voltage. When I left the cabin lights on, they went tango union very quickly. Two new DieHards are now in place and it's a beautiful day in Prosser Washington. Thanks, again
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Brake controller adjustment problem Zettervall Brakes & Brake Controllers 9 08-30-2011 07:58 PM
How low is too low? Mrs. Bale Electrical - Systems, Generators, Batteries & Solar 6 08-16-2011 07:19 PM
