Old 08-06-2010, 06:32 AM   #1
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Weird lights
I have a 1975 Argosy 20 footer that I am currently in the process of refurbishing. When hooked to the tow vehicle, none of the running lights work. Yesterday, my buddy and I were inside repalacing some water lines.
We had hooked up to shore power so we could run a fan. The Univolt was running and charging the junk battery that is currently in the trailer. Last night I went out to unplug the shore power and ALL of my running lights are on! I am not hooked to the truck either. I unplugged the shore power and the lights stayed on until the battery went dead. I am baffled as to where these two systems might cross. I don't have any schematics to work off of. Any thoughts?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-06-2010, 09:13 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
One thing that is important is the ground. if there is a poor ground the power will look for a path for ground. it will go thruogh lights and any thing that is in the same system and find a path to ground. I've seen stranger things happen in the 20 years that I worked in an automotive electrical shop. Clean every ground connection that you can find and you will probably get your clearance lights working
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 08-06-2010, 10:57 AM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Open the trailer plug in for the truck and see if there is anything corroded or connecting the top terminals as the lights and power are beside each other. Any connection will put the lights on till the battery goes dead.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-07-2010, 07:42 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
ground wire
I saw this very thing one time. There was corrosion on the ground in the plug and was corroded to the point that it in two. The running and STT lights stayed on.
Where ever your problem, it does sound like a bad ground.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 08-07-2010, 08:38 AM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
My running light problem was different. Mine are fed off a green wire at the 7 way plug and testing with a multi-meter showed a dead short. I replaced all the marker light fixtures and installed new bulbs in all the rear lights and it all worked. My 7 way plug was messed up by the PO and my break away switch was there but bypassed. I just re-wired everything at the 7 way entrance and now it all works. I did order a AS service manual when I first bought the trailer. Best $60 I spent so far.
The 7-way tester is the best $25 I've spent so far.
Gary
Old 08-12-2010, 08:11 PM   #6
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Thanks for all the input. Today I finally got back to the trailer. First thing I did was change the 7-way connector. After changing that out I hooked the cord to the truck and voila!! the running lights worked. Hooked to shore power and all is as it should be.
Thanks again,
Bruce
Weird Discoloration evsjr Roof Vents, Skylights & Fans 3 08-03-2009 08:51 PM
Really Weird Bedspread SRW Upholstery, Blinds, Walls & Interior Finishes 11 06-24-2009 08:12 AM
weird noises and lights dimming slapshift Lights - Interior & Exterior 5 09-01-2008 04:59 AM
weird!!! rebel beck Plumbing - Systems & Fixtures 8 06-29-2006 09:06 AM
