Old 10-03-2005, 02:27 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
weird electrical problems
so I installed a "new" automotive stereo in the camper a few weeks back. ("new"= "hand-me-down", but way newer than 1973. probably a '93 model, all-electronic, etc, etc). Just noticed some odd behavior. While listening to the radio, if I turn on the galley light, the sound cuts out compltetely. The stereo stays on; just no sound. shut off the galley light...sound returns. same thing with one of the overhead lights, although, I think one of them actually did shut the stereo off entirely.
at first, I thought it might be because the battery was disconnected, as I've read that it acts like a "buffer", of sorts. but plugging in the battery doesn't change anything.
also noticed on the last outing....had TV on, (current model...2 years old, ac/dc CRT), connected to shore power, 30 amp, no extension... when the furnace blower kicked on, TV got all wonky. (looked like scrambled cable). It didn't return to normal after the blower shut down. Tried "re-booting" to de-gauss the tube, but that didn't seem to work, either. So I unplugged it from 110, and plugged it into 12v recepticle. Picture came back (weak signal during this whole test...possibly related?), but now the univolt "hummm..." was coming through to the sound, and a solid line passing through the pic. never seen this before.
Univolt seems to be working properly. At last test, it was putting out a steady 13.5v. I can't think of what may have changed on the system that would be causing these oddities. only thing that comes to mind is that I did have the furnace out a couple of weeks ago to replace the thermocouple. so it got disconnected/re-connected to power.
Didn't think to check the TV over the weekend, whilst plugged into "known good" power at home. But the radio acted up. (had the ball game on while puttering outside....GO SOX!!!)
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-03-2005, 03:38 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The heater / TV problem sounds like a fan is bad and putting out electical noise. The problem with the radio and the sound cutting out might be resolved with a string of garlic.
Richard
Old 10-03-2005, 04:00 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
How about...
You have a speaker wire output hooked up to a 12v power line at the radio? It may also explain the odd behavior of the TV set. You are feeding back power into the radio, causing it to become a transmitter, and it is jamming the TV signal. Try unhooking the radio, and see if the TV starts working again. If that doesn't do it, I can refer you to a good exorcist...
Old 10-03-2005, 04:39 PM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
that would be difficult to achieve. power supply isn't anywhere near the speaker wire bundles, and each speaker line has a factory installed plug-like connector.
also, these symptoms were occuring independantly...when the tv was acting up, the radio was not on, and when the radio was acting up, the tv was not on.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 10-03-2005, 04:42 PM   #5
1993 21' Sovereign
So, was any of this happening before the "newsed" radio install?
Old 10-03-2005, 04:58 PM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
no. the old radio wasn't original, but it was "older". had a cassette player, but an analog tuner.
the TV has been sensitive to low voltage, or sudden drops in voltage, when running on 12v. but on 110, has never shown any trouble at all. I suspect that modern stuff...even stuff meant for 12v systems, needs to be in a much narrower range than older stuff would tolerate. but that doesn't explain the radio's behavior. it cut out even when plugged into shore power. even though its always "12v", the voltage should be steady when coming through the converter, yes? (maybe no...).
probably a bad ground. odd symptoms almost always mean "bad ground", don't they?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 10-03-2005, 06:30 PM   #7
1993 21' Sovereign
My experience has been that when you do something, and you immediately have a problem, chances are good it was at least in part something you did or did not do when you did what you did.
Umm, that doesn't look right, but I don't know how to fix it...
Anyway, it is probably something to do with the newsed radio, or the install.
Old 10-03-2005, 09:44 PM   #8
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
weird electrical
I wired a cd/radio from a late model vehicle and the audio went bad the first time I used it when plugged into shore power. The ac ripple from the univolt apparently screwed with the radio. The battery is a filter for the ac ripple but I did not wire directly into the battery. If I try another radio I will run a wire straight from the battery. Just food for thought.
72 tradewind is offline   Reply With Quote
Old 10-04-2005, 07:03 AM   #9
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Me too. Brand new CD player bit the dust
smily is offline   Reply With Quote
Old 10-04-2005, 01:05 PM   #10
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Grounds, Voltage Drops and High Resistance
Most of these difficulties sound a lot like voltage drop and poor body grounds.
I don't know when Airstream stopped using aluminum wiring but I can tell you that my GT has had It's share of hot outlets and even arcing at connections in both the outlets and by the battery. The aluminum wire had developed corrosion causing resistance, causing heat, loosening terminals, causing more resistance, ect, ect.
Even with copper wiring there are still body grounds, (more aluminum), to cause voltage drops and the resulting lackluster performance of lights, fans and all of our creature comfort items.
I've replaced the breaker box, breakers and cleaned and tightened wiring in the battery compartment and replaced some outlets with some success maybe this could be of help to you as well.
Good luck, Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 10-04-2005, 01:48 PM   #11
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I don't know when Airstream stopped using aluminum wiring but I can tell you that my GT has had It's share of hot outlets and even arcing at connections in both the outlets and by the battery. The aluminum wire had developed corrosion causing resistance, causing heat, loosening terminals, causing more resistance, ect, ect.....
Good luck, Tom.
I don't know the year either, but my '73 Overlander has copper wire. A good muti-meter may be the answer for Chuck's '73. It really sounds to me like a bad ground or voltage in the wrong place either on the "newsed" radio or even worse, the heater.
Good Luck, Jim
www.nesa.org
Air No. 6427
Old 10-04-2005, 03:18 PM   #12
Retired and Retreaded
edmatlock's Avatar
1972 26' Argosy 26
1978 28' Argosy 28
Oklahoma City , Oklahoma
Send a message via Yahoo to edmatlock
Radio quits
The radio you have requires a non-grounded speaker. If you are using the original Airstream installed speakers, one wire is maybe grounded to the trailer. You can't rewire all the speakers because the wire is in the wall. You can go to radio shack and get a 8 ohm to 8 ohm transformer for each channel and that may fix it.
ED MATLOCK
edmatlock is offline   Reply With Quote
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 08:20 PM
I have made many electrical changes FrankR Electrical - Systems, Generators, Batteries & Solar 4 10-03-2008 09:53 AM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 10:40 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 08:39 PM
