Old 09-11-2006, 06:47 AM   #1
1962 19' Globetrotter
2001 31' Excella
Water Pump Replacement ?
My original 1978 PAR water pump finally bit the dust. I bought a new shurflo to use as a replacement. The old water pump had one orange and one white wire connected to black and blue wires on the PAR water pump.
The new shurflo has has one black and one red wire - how do I connect this to the old wires? I'm assuming trailer orange to pump black and trailer white to pump red, but wanted to make sure.
Thanks!
Craig is offline   Reply With Quote
Old 09-11-2006, 07:35 AM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Thanks!
Vice versa? I had trailer black, and trailer white. I hooked the black to black, and the red to white. (Actually I think it will work either way, try it and see)
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 09-11-2006, 07:55 AM   #3
Images: 59
I vote the other way. The black on the pump is ground, red goes to the switch and fuse panel.
On the trailer side, the white is the ground, and the colored wire is positive. So it would be trailer white to pump black, and trailer orange to pump red.
Test it before you make the connections permanent.
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Water Pump InsideOut Water Heaters, Filters & Pumps 4 06-05-2002 07:28 AM
