Help: Need panel indicator light for water pump in 76 sov. Inland has $25.00 min. order Out of doors mart does not have any. Any one have source where to pur.?
is it an incandescent 12 volt bulb, or a red LED? There was a change about that time from one to the other. If it is just the bulb, you can get it at any auto parts place. If it is an LED most likely you have a wiring issue, as they almost never burn out.
McMaster-carr does not show any indicator lights when I googled web sight
You will likely have better results searching within their website rather than using Google. Here's a link to the section you need. Recognize that you may, or may not find a direct "plug and go" replacement.
