Old 02-27-2013, 10:25 AM   #1
1976 31' Sovereign
Oswego , Illinois
Smile water pump on off indicator light
Help: Need panel indicator light for water pump in 76 sov. Inland has $25.00 min. order Out of doors mart does not have any. Any one have source where to pur.?
Old 02-27-2013, 11:18 AM   #2
Kevin245's Avatar
Have you checked Radio Shack or McMaster-Carr for a suitable alternative?
Eleanor Roosevelt
Old 02-27-2013, 11:28 AM   #3
1976 31' Sovereign
Oswego , Illinois
McMaster-carr does not show any indicator lights when I googled web sight
Old 02-27-2013, 11:43 AM   #4
1974 Argosy 20
Kooskia , Idaho
is it an incandescent 12 volt bulb, or a red LED? There was a change about that time from one to the other. If it is just the bulb, you can get it at any auto parts place. If it is an LED most likely you have a wiring issue, as they almost never burn out.
Old 02-27-2013, 12:11 PM   #5
1976 31' Sovereign
Oswego , Illinois
It is sealed red rectangle light no led lights in 1976 AS that I am aware of no wiring issue just burned out
Old 02-27-2013, 12:50 PM   #6
Kevin245's Avatar
You will likely have better results searching within their website rather than using Google. Here's a link to the section you need. Recognize that you may, or may not find a direct "plug and go" replacement.
McMaster-Carr
Eleanor Roosevelt
Old 03-01-2013, 09:09 PM   #7
1974 Argosy 20
Kooskia , Idaho
These are some small LED indicator lights from Radio Shack, maybe you could substitute one for this use:
LED holders & assemblies - LEDs - RadioShack.com
Old 03-01-2013, 09:16 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Anything else you need from Inland?
It's pretty easy to get to $25.
New vent gaskets, grease seals, break-away switch, Tempro, rivets, ect...
