Old 05-14-2015, 01:38 PM   #1
hst68's Avatar
1972 23' Safari
Müllheim , Thurgau
water Level Sensores
I need some help for the fresh water tank level sensors.
How to connect the four cables (red/white, green/white, brown, black), the Central Control Panel Connector on?
I restore an Airstream Safari Landyacht 1972 23''
Is there a cable Schematic or images?
Thanks for your support
greeting from Switzerland
hst68 is offline   Reply With Quote
Old 05-14-2015, 07:03 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello from Minnesota, USA! I'm glad you found these Air Forums. It is great to have European connections to our discussions.
Alas, I do not have a wiring diagram for the 73 Safari. I simply replaced my water level sensor with a new modern one for $250. It works much better. I hope you can get yours working.
I believe someone will respond to your question in short order.
Here is a photo of my 66 Trade Wind. I've been "fixing it up" and have it almost ready for traveling again.
David
Name:	1410 Street View.jpg
dbj216 is online now   Reply With Quote
Old 05-14-2015, 11:09 PM   #3
hst68's Avatar
1972 23' Safari
Müllheim , Thurgau
Hello David
Thanks for your answer.
a few pictures of the wiring and my Airstream
ID:	238454   Click image for larger version
ID:	238457   Click image for larger version
Old 05-15-2015, 05:01 AM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Wow, that is quite a bundle of wires coming into that connector. I'm hopeful someone will post the wiring schematic for your 73 Safari.
I installed the Garnet SeeLevel fluid level sensors in my 66 Trade Wind. This old Airstream did not have any level sensors installed when it was built. The SeeLevel system seems accurate and reliable. The sensor circuits literally stick to the outside of the tank. Very easy to install.
Here is a photo of my new fresh water tank with the sensor circuit applied to the side of the tank. The tank is laying on its side in this photo.
Your old Safari looks nice with the awning out. I see you are building a new interior for your Safari. Big project!
David
Name:	1404 Plumbing Fresh Tank SeeLevel.jpg
Old 05-16-2015, 08:44 AM   #5
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
HST68 is that a claw foot tub in the bathroom. Quite nifty.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 05-17-2015, 12:52 AM   #6
hst68's Avatar
1972 23' Safari
Müllheim , Thurgau
Yes, this is a free-standing bathtub. A service of my wife, for this project
Water level - does it include the water heater's 6 gallons GP1152 2005 and newer - Bambi all models 20 08-06-2016 09:29 PM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
fresh water tank level and pumping Lumatic Fresh Water Systems 8 12-24-2007 05:51 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Don't forget: Check your battery water level.... Safari Tim Batteries, Univolts, Converters & Inverters 2 11-14-2004 12:30 PM
