Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-27-2007, 05:55 PM   #1
walter1
Profile:
Water heater wiring
What size wire should I use to run from the switch to the electic part of the water heater?
The wire I removed (due to old cracked insulation) is labled 14/3 600 volt. Not sure who put it in.
It's a 4 foot run from heater element box to the switch.
From switch to 20A circuit breaker is 6 foot run of 10/3 romex type house wire.
Can I use regular 14/3 or does it need this heavy duty 600 volt wire?
Perhaps 12/3 or 10/3 extension cord type wire? Or heavy duty 12/3 dryer plug wire?
Thanks, Walter
walter1 is offline   Reply With Quote
Old 04-27-2007, 08:23 PM   #2
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Smile Hi
What is the watage use of your water heate.? I now it is 120v ac but how much current will it use? Power=120X amps. Use wire that is a cable type. It is made from many small wires that are flexible and will carry more current.Solid wires have tendancy to break from vibration,
Regard Russell in sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 04-27-2007, 08:32 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Russell is right!
Walter,
14/3 is rated for 15 amps, 12/3 is tared for 20 amps. The water heater will not draw mote than that. Most usually contain a 1200-1500 watt heating element that will draw 10-12.5 amps. 14/3 will handle this, but I would use 12/3 anyway as a margin of safety.
If you really want to go top shelf, use a stranded marine cable in that size. It is far superior to any solid copper Romex type wiring and will NEVER BREAK from work hardening as the wires continually bounce down the road.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 03:29 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 10:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 11:13 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 09:36 AM
test
