It could be that the usage of hot water was less while plugged in at home. Check the screw connection at the breaker and be sure it is tight. Loose connections are a common cause of heat. Also as Overlander63 mentioned if the voltage is unusually low the amperage will be higher and cause overheating.
Sorry slow reply.
Appeared voltage good. However, once home and on our current trip there is not the same heat issue. Had to be the campground power was low.
It is interesting tho....the panel does generate some heat. As does my panel at home. Temp runs about 8-10 degrees above ambient at load.
I will monitor properly in the future. Thanks!
Peace and Blessings..
Channing
WBCCI# 30676
