Old 08-18-2008, 07:04 AM   #29
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
The change out to fluorescent also dropped my amperage draw per fixture down from 9.4 Amps per fixture to 2.21 (I metered it with a clamp-on). That is a total savings of nearly 29 amps if everything is on.
It is also substantially cooler inside with less heat being generated.
trevisgardne is offline   Reply With Quote
Old 08-18-2008, 09:02 AM   #30
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Hey wht about differencein lighting moreor leslight?
I might think of purchasing some of those when I put the Fantastic Fans in front and back of trailer where did youget yours?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 08-20-2008, 04:28 AM   #31
Dan@LED4RV's Avatar
Denton , North Carolina
Here is that switch
Originally Posted by DPeakMD View Post
become a serious problem as it was well on its way to melting through the plastic.
Here is a link to that replacement switch from Airstream.
There are few things that you can do to your Airstream that can make a big improvement for so little work, as replace that Lens.
Here is a link to that lens.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
