Old 04-11-2010, 04:21 AM   #1
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Want To Install 3 Stage Charger 1999 Safari
I just purchased this Safari and it has the Magnetek 900 installed. It appears that this is a single stage charger. I would like to replace it with a 3 stage "smart" charger like the Iota that was in my Jayco. I am just curious as to what you might recommend both brand and size wise. Right now the coach only as a single 27 battery. FYI, I will likely upgrade to 2 6v Trojans again as I was running in the Jayco. I also might install a Trimetric like I had in the SOB, any recommendations on a mounting location (giving consideration to running wires and such and not wanting to tear apart the interior).
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 04-11-2010, 07:37 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You should be able to simply remove the old, and install the new, in the same location. I've had good luck with the Intellipower converters, though you can contact Randy at Best Converters (68overlander). He can give you a little more insight. A 45 amp converter should be more than enough.
Old 04-11-2010, 08:00 AM   #3
Soyboy's Avatar
1999 28' Excella
Images: 44
Terry, thanks. In the meantime, should I be turning the current (no pun intended) converter on and off? I ask as I see there is a switch by the door.
1999 28' Safari
KC3MAP
Old 04-15-2010, 06:27 AM   #4
Soyboy's Avatar
1999 28' Excella
Images: 44
Follow up, I ordered an Iota DLS 45 with Q4 from Randy this week.
1999 28' Safari
KC3MAP
Used 1999 airstream 28' safari travel trailer used 1999 eBay Watch Airstreams on eBay 0 09-11-2009 08:40 AM
Used 1999 airstream 28' safari travel trailer used 1999 eBay Watch Airstreams on eBay 0 08-19-2009 11:50 AM
Tru charge battery charger install? nsteel Batteries, Univolts, Converters & Inverters 0 11-21-2007 08:09 AM
Safari 1999 michaelcurti Member Introductions 1 09-06-2006 07:17 AM
