Old 07-06-2016, 07:52 PM   #1
Wilton , California
Voyager back up camera
Hello group,
Were thinking of installing a backup camera, looks like most people like the voyager. With that unit how many holes will have to be drilled into the new AS to mount the camera?
4t9ers is offline   Reply With Quote
Old 07-06-2016, 08:09 PM   #2
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
4t9ers
Two screw holes for the mount and one for the cable (grommet is provided in the kit).
Most people connect the camera power supply to the running light 12V supply. This can be a chore to locate and connect to so be sure you are up to this before attempting DIY.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 07-06-2016, 08:17 PM   #3
2016 25' Flying Cloud
Louisville , Kentucky
I had the Voyager installed by an Airstream dealer. I believe there is only one hole near the center rear running light. It is powered by tying into that running light's power. Regarding use, I am really glad I had it installed. For me, it does not replace having someone guiding while backing up due to the fish eye distortion but I can at least hear their instructions and motions. The real value is rolling down the road and knowing if someone is behind you. Some drivers have a nasty habit of tailgating and whipping around at the most inopportune moment -- like when you decide to change lanes. Some people complain about the slight delay in the image (1/2 to 1 sec. behind real time). I have not found it to be a big issue as I am only glancing at the monitor occasionally.
Candominium is offline   Reply With Quote
Old 07-06-2016, 08:40 PM   #4
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
If you're doing it DYI like Ohiobrits did....and as I did....it is three holes. If you use the "wire it to the center clearance light" solution -- which is the easiest, just remember that you do have to turn on your clearance lights to power up the camera. Frankly, I think keeping them light provides a bit of a plus to daytime visibility. The hardest part of the install was getting the clearance light loose from the base -- there are two spring clips in there as well as some VHB tape. You'll have new respect for VHB tape after you loosen it!
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-06-2016, 09:21 PM   #5
Wilton , California
Thanks for the reply guys!
Old 07-06-2016, 09:57 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
HOLES!!!!!!!!!!!??????????????
I don't make no stinking holes!!!!!!!!!!!!!!
3M VHB tape for the bracket, then surround the edges and cover the base completely with SikaFlex 221 in grey.
Still no holes!
Remove the center running light (it pries up and is held on with 2 internal metal clips and a piece of pesky double sided tape) and remove the 2 mounting screws underneath.
You can make a small hole in the rear sidewall of the light housing and splice into the running light wire.
HINT*** attach the connector and zip tie it to the bracket, then wire the extended cord into the light housing. This will allow for removal/replacement of the camera if you have any problems with it. Just snap on a new one and pop the connectors together.......
No holes.......NO LEAKS!!!!!!
Old 07-06-2016, 10:27 PM   #7
Wilton , California
Lewster,
Great ideal. I'm a auto tech so I have that 3m tape. Install a little silicon in the hole in the light and boom no holes nice!
Old 07-06-2016, 10:44 PM   #8
lewster's Avatar
Originally Posted by 4t9ers View Post
Lewster,
I wouldn't use any type of silicone around an aluminum Airstream!!!! You won't like the results! Polyurethane sealants ONLY!!!
Old 07-06-2016, 11:19 PM   #9
Wilton , California
That's what I ment to say. I'll use a Dremel to make a little hole in the crome around the light. Thanks for the great input.
Old 07-06-2016, 11:35 PM   #10
Wilton , California
Lewster,
Do you have a model number on the 3m vhb tape you like to use?
Old 07-07-2016, 12:37 AM   #11
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Anyone got a good source for the 7" wireless Voyager system? Jensen, RVCams, and Amazon seem to be the ones that come up on a Google search. Any other sources worth considering? Pat
PKI is online now   Reply With Quote
Old 07-07-2016, 07:26 AM   #12
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I just reviewed the new Voyager camera system on my youtube channel:
The display is a 5" and can support up to 5 cameras (4 wireless and one wired). I am not sure when the release date is but it is probably soon since I got one to review already.
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 07-07-2016, 12:24 PM   #13
2014 25' Flying Cloud
Colorado Springs , Colorado
Here's a wireless backup camera I'm thinking about buying: https://pearlauto.com/rearvision
Losman is offline   Reply With Quote
Old 07-07-2016, 12:33 PM   #14
2018 25' Flying Cloud
Hillsboro , Oregon
My dealer installed a www.rearviewsafety.com brand camera. So far, so good. I believe it was the 7" 2CAM package. I also bought another wireless camera that I clamp to the tailgate when hitching up.
Roguegaston is offline   Reply With Quote
Old 07-07-2016, 08:14 PM   #15
lewster's Avatar
lewster,
do you have a model number on the 3m vhb tape you like to use?
4950
Old 07-09-2016, 07:58 PM   #16
Wilton , California
Lewster,
How are you hiding all the wire on the voyager back up camera with out hiding it under the skin with a hole. Do you have a picture you can post?thanks
Old 07-10-2016, 12:04 AM   #17
lewster's Avatar
Lewster,
I don't hide the wires as all............. just neatly compact them and zip tie them to the frame of the camera. I used to wrap the wires with loom and cut off the connector plug, but soon realized that if you have a camera defect which requires replacement, you would have to disassemble the entire installation to replace the camera.
With the snap-in waterproof plug that's provided by Voyager, camera replacement is a plug and play affair with no wiring required. The potential for an easy replacement of the camera far outweighs the visual of seeing a tiny wire bundle and is an arrangement that most of my clients prefer.
Hiding the wires requires a hole drilled in the skin under the camera mount plate, fishing in into the interior and splicing it into the running lights IF you can find the appropriate wiring. You need to remove the center interior cabinet light and work thru a 3" hole in the aluminum. Definitely NOT for the faint of heart as there isn't much slack in those wires!!!
Old 07-10-2016, 12:19 AM   #18
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Tagging in so I can find this later
Tks
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 07-10-2016, 12:27 AM   #19
Arcticfox's Avatar
Central , Canada
I see this 3M#4950 tape is available in different widths. What width do you find most practical to have in your tool box.
Doug
Old 07-10-2016, 12:58 AM   #20
lewster's Avatar
Doug
The large rolls that I use don't quite fit my tool box, unless you consider my entire eSprinter van the 'toolbox'........ which it really is!
Anyway...........1" seems to do very nicely!
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 55 08-01-2018 07:54 PM
Voyager rear view camera image upside down jamieb1086 Audio, Video & TV 11 05-18-2018 06:32 PM
Voyager WiSight Camera works 50% of the time. Ted S. Electronics & Connectivity 14 08-20-2015 10:54 PM
Voyager wireless camera DeltaRon Electronics & Connectivity 6 06-16-2015 07:32 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
