Old 09-28-2015, 06:07 AM   #15
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
There is a You tube video that shows that the three light testers are not infallible for detecting hot skins. You need to use one of the Non-contact pencil type voltage detectors as well. Klien, Milwaukee, and Eline makes good ones for less than $20. I own 2 Milwaukee's. One for me and one for the club. The prime products tester (above) is simply a 3 light tester mounted in the trailer. You need to park and plug in before you know the site is unsuitable. I keep my testers in the side pocket of my truck to test before I back in. It eliminates the need to reback in the trailer and truck.
Old 09-28-2015, 06:46 PM   #16
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
good suggestion.. plug before play..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 09-28-2015, 07:43 PM   #17
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I've equipped both of my trailers with a Progressive Industries set up that will NOT connect my trailer to ANY pedestal if there's any kind of problem with the incoming current. If there is a problem, it gives me a code and tells me what's wrong....reversed polarity, ground, neutral issue, etc. It also gives me the voltage that's coming into my trailer. Since I have a 50amp service it gives me the voltage on EACH of the two legs. You would (maybe) be surprised how many campgrounds are feeding an underplot (like 108V) to your trailer. This can be an issue with the A/C. The PI devices also have a surge protector as part of their set up. They cost a bit of $, but well worth it for the peace of mind, IMHO.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-30-2015, 12:45 PM   #18
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
X2^ check the pedestal prior to plugging the coach in! It's better to detect the problem without touching a tingly shell!
Old 10-05-2015, 02:47 AM   #19
1977 31' Sovereign
1989 34' Excella
I use the three light tester with a 30 amp adapter before I back in. The non-contact tester assures me that the trailer skin is properly grounded. The problem can be in the trailer or appliances as well as the pedestal. It is important to keep one metal stabilizer (or jack stand) in contact with the ground, just to be safe. The fancy surge protectors are nice but $.
Old 10-05-2015, 06:50 AM   #20
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
This is the video to watch.
I also have a surge protector and I chose to hard wire it in the trailer. Also have the non contact tester, monitor AC and DC inside the AS and carry a multi meter.
Another issue I'll put out is check the post receptacle when you plug in, does the plug have some bite or flop around? If it flops, suspicious that the receptacle is cooked and has lost tension on your plug blades to make a good connection and might cause low voltage and heat at plug damaging plug. I carry a spare plug.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-05-2015, 08:30 AM   #21
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Simply having a stabilizer or post down offers zero ground!
Old 10-05-2015, 01:22 PM   #22
2014 23' Flying Cloud
Park City , Utah
Following.
I'm picking up a 2013 Flying Cloud 19 next week and then going on a maiden voyage to the Oregon State Parks, all with Electric Hookups. I want to definitely get one of these tower mount units. I'll go with the Progressive, the Technology Research one sounds like the reliability and Customer Service isn't as good.
Do I need the 30 amp or 50 amp for my Flying Cloud? I can't tell from the spec sheet, which just says "110V/12V Power Center w/55 amp converter."
pcskier is offline   Reply With Quote
Old 10-07-2015, 08:37 PM   #23
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by pcskier View Post
Following.
Your 19 foot FC only has one AC unit so it will be set up for 30 amp service. All you need is a 30 amp surge protector. You should have a set of adapters (50 to 30 amp, and 15 to 30 amp) so you can plug in under all circumstances you are likely to run into.
Bob Martel
WBCCI# 5766
New gas lines and pressure tester Splitrock Stoves, Ovens & Microwaves 2 08-29-2010 07:12 PM
lcd digital voltmeter display Havana Batteries, Univolts, Converters & Inverters 0 08-18-2010 06:32 PM
Voltmeter Stone Ridge Lights - Interior & Exterior 6 01-20-2009 07:16 PM
Digital Panel Voltmeter source wacnstac Batteries, Univolts, Converters & Inverters 13 05-30-2007 06:50 AM
voltmeter ALANSD Mechanics Corner - Engines, Transmission & More... 10 07-06-2002 08:13 AM
Recent Discussions
