12-16-2018, 06:11 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Victron BMV monitor location
Post pics of your Victron BMV monitor location. I’m looking to mount mine in our 2014 23D and want ideas.
I have the prewire prepped to use but.... where I want to mount the monitor in the wall by the tank monitor display there is a up and down aluminum rib.
I’m thinking over the microwave or beside the living area TV.
Any info would be greatly appreciated.
I know the unit is Bluetooth and can be hidden but I want to be able to uses the head unit also.
12-16-2018, 06:34 PM
2022 25' Flying Cloud
NCR
, Ontario
this is my mounting above the fridge in an AS 22FB sport
12-16-2018, 06:40 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Mine is mounted under the sofa completely out of sight. The bluetooth connection is fine for whatever I need to see.
12-16-2018, 07:11 PM
2018 19' Flying Cloud
Newport
I wanted mine out of sight but easily accessible. I also wasn't inclined to want to cut into any cabinetry or metal. I picked up a cheap gauge mount bracket at my local auto parts store and mounted the meter just inside the cabinet under the kitchen sink.
https://i.imgur.com/0c6sry6.jpg
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
12-16-2018, 08:37 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The monitor itself is stuck to the Classics 'mouse fur' with my trusty velcro....behind the curtains.
I keep track in the house on the mac.
"You don't know where you've been until you leave, enjoy life" RLC
12-16-2018, 08:59 PM
2018 28' International
Renton
We too didn’t want a hole in the wall so we opted to have AM Solar put it on the rear inside bulkhead of the overhead cabinet. Easily accessible but non-obtrusive. 99% of the time I will use the BlueTooth app for all functions.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
12-17-2018, 09:51 AM
2018 25' Flying Cloud
Portland
, Oregon
On the 25’ there are panels inside the bathroom on either side of the door at 45 degree angle. One of these is a chase for the black vent pipe. The other, though, is just there for cosmetic purposes. This allows you to cut a hole in the wood facing the hall and mount the gauge there with the rear of the BMV concealed inside that 45 degree void. Sorry, no pictures. It’s a very handy location.
Not sure if there is anything similar in your 23’s bathroom. You might poke around.
Even though ours is Bluetooth I do find we look at it several times a day so I’m glad I didn’t bury it.
12-17-2018, 09:30 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
I have mine inside one of the external compartments, facing outward. This allows me to peek in through the access door and read the gauge if I'm outside without my phone/bluetooth.
Honestly... once you get used to it, you'll check the battery less and less.
12-17-2018, 09:37 PM
2017 22' Sport
Johns Creek
, Georgia
In our 2017 Sport 22, right next to the JVC radio
12-17-2018, 10:53 PM
2019 27' Globetrotter
Salem
, Oregon
In my 23 International I mounted it next to upper cabnet.
12-17-2018, 10:55 PM
Salem
, Oregon
Next too upper cabnet
12-18-2018, 10:51 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
That's been my experience. I do a once a day or once every couple days (depends on how we are camping) check on solar and battery. Checking the history logs is as much part of it as anything else. The little monitor gizmo gives you a lot less information than the phone app.
I ran with the monitor "out in the open" for a while and then decided it was taking up space needlessly.
12-19-2018, 05:31 PM
2016 30' International
redondo beach
In the galley where the factory solar display used to be.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
06-04-2020, 11:02 AM
SurfnStream
2020 16' Caravel
San Clemente
, CA
Bumping this thread- anyone have pics of their installation in a newer Bambi/Caravel?
06-06-2020, 08:35 AM
lookingin
Golden
We used a small detached mount that can pivot. I felt that it was too likely that other equipment would come in to play later and for that reason did not want to core into the walls.
06-06-2020, 10:08 AM
2020 25' Globetrotter
Los Gatos
Came in the box so might as well use it but never look at it. Bluetooth baby
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
06-15-2020, 11:45 AM
2017 23' Flying Cloud
Beavercreek
, Ohio
I have a 2017 23D and originally mounted mine in the storage compartment below the couch, but moved it to a more decorative mount and placed it on top a shelf I built. All secured with command strips, no holes.
06-24-2020, 07:48 PM
Parker
Under sofa cabinet.... no need to see it with color gx installed
Troutboy
06-24-2020, 08:09 PM
Newport
Take a look at posting #4 where I provided a link to a picture of the installation in our 2018 Bambi.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Question regarding Victron BMV-712
billrector |
Batteries, Univolts, Converters & Inverters |
26 |
05-30-2018 03:21 PM |
Victron BMV-712 install in 2017 30 International
dmcgaugh |
3 |
03-09-2018 12:24 AM |
Incorrect readings Victron BMV-702
NoResults |
1 |
06-01-2017 03:51 PM |
Victron BMV 702 install using solar prewire
Brav |
4 |
11-21-2016 01:22 AM |
Victron Energy BMV-702 Battery Monitor
TinVenture |
Electrical - Systems, Generators, Batteries & Solar |
5 |
10-15-2016 08:49 AM |
