Old 11-18-2018, 08:26 AM   #1
2019 22' Sport
Quartzsite , Arizona
Victron BMV-712 Install Question
Howdy,
This seems like a good "easy" upgrade. Being new to RV's and Airstreams I want to make sure I do it right the first time.
I have a 2019 Sport 22FB and I just took a look under the bed platform and saw the rats nest of wires of which I understand very little.
I have the factory solar option installed.
[Side note: I was a contractor and worked with lots of home electrical systems. Minor old time auto electric... but I'm good at this sort of thing]
I am assuming I leave ALL the wiring in tact for now and simply splice the shunt in the negative cable.
I have also see mention of a power lead to the "buss bar" but I see a number of bus bars throughout the Sport.....
Anyone done an install on late model Sport 22FB that has photos to share?
I'm about tapped out with what I want to invest this time around so along with new converter and adding a second 12v battery that will be my upgrade.
Remember easy is relative. "Whiskey Before Breakfast" is "easy" to play on guitar AFTER you learn it!
Rounder44
Rounder44 is offline   Reply With Quote
Old 11-18-2018, 08:38 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
snip..."I am assuming I leave ALL the wiring in tact for now and simply splice the shunt in the negative cable."
Exactly what I did...In our Classic the two batt's are in separate compartments. I brought both negative Cables together and connected them to the battery side of the shunt.
The out side of the shunt going to the Neg buss bar.
Once I got everything wired and working I did replace some of the cables with the new six gauge.
For breakfast....
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-18-2018, 10:02 AM   #3
2019 22' Sport
[QUOTE=ROBERT CROSS;2181251]snip..."I am assuming I leave ALL the wiring in tact for now and simply splice the shunt in the negative cable."
Hmmm..
You didn't wire the batteries together negative to negative, positive to positive and then positive off of one battery and negative off the other like in my diagram.....????
That's how I gathered I'm supposed to do it....
Confused...
R44
Old 11-18-2018, 04:14 PM   #4
[QUOTE=Rounder44;2181293]
Hmmm..
Confused...
R44
Your diagram is correct.
Our wiring is different only because of the separate battery compartments, the wiring joins at the pos&neg buss bars.
W. H. Auden
Amanamus
"Tahawus"
Old 11-19-2018, 06:47 PM   #5
2019 22' Sport
Hi,
Having trouble determining which is negative direct from battery... and if that is in fact which I splice into. (Batteries are out of the AS, no shore power!)
BUT I think my photo is what I need...???
The photo is almost straight down, wood is the floor, so the main harness is coming up from the bottom.Possible bus bar labeled top left.
Do I just cut that black wire and splice the shunt in? Should be enough length...
R44
Old 11-19-2018, 06:59 PM   #6
That is one neg cable from one battery?
Yes...that is correct.
W. H. Auden
Amanamus
"Tahawus"
Old 11-19-2018, 07:48 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You are slightly better off if you run a cable from each negative post directly to the shunt.
uncle_bob is online now   Reply With Quote
Old 11-19-2018, 08:59 PM   #8
Am I rong?
The 22' Sport has but one battery with one negative cable. 😂
W. H. Auden
Amanamus
"Tahawus"
Old 11-19-2018, 09:40 PM   #9
2019 22' Sport
Hi
How you you fish a second cable through?
Seems to go into a space between exterior and the floor so the holes are offset.... and sealed.....
R44
Old 11-19-2018, 10:26 PM   #10
So the new 22's have 2 batts? with just one cable running to the negative buss bar?
The single negative wire & single neg buss bar is all that is in your system?
As Bob 1 noted...."slightly" may not be noticed.
But I did follow his advise.
Our Classic had a two into one wire set-up before I changed it when I upgraded the OEM converter in 2007.
For the Victron shunt I was able to lengthen them and connect both directly.
PITA to get to them but most of stuff was apart and out of the way.
Do you plan on a converter upgrade down the road?
It may be an easier job if you do.
W. H. Auden
Amanamus
"Tahawus"
Old 11-19-2018, 10:59 PM   #11
2019 22' Sport
I am adding a second battery.
Right now single wire and bus bar. I don’t think I’ll have to add a bus bar......
Upgrading to Wildkat converter at same time batteries go back in. How would new converter make it easier?
I could grease up a couple wires and tie onto existing negative and see if that pulls them through but I’d hate to loose it in the “space” between. I’ll look closer.
I could also punch a new hole in the bottom as I don’t think there’s much there but need to be 100% before I considered that seriously.
Haha! All the threads I read said it’d be easy!��
Thanks!
R44
Old 11-20-2018, 06:44 AM   #12
If it is that difficult and requires a 'hole'... I would just splice into the one wire and go with it.
When I contacted Victron and explained my situation they advised I could do exactly that. But I had everything apart and decided to just lengthen the second wire and attach directly to the neg bar.
In my case having the converter out just opened up the space making it much easier to get to the wire that was to short.
Good on 'ya...the second battery and converter is a excellent first upgrade.
Make sure they match, even consider two new, are they Interstate?
You may be able to have the dealer pro-rate the one you have so you end up with two that match.
We learned the hard way on our first boon docking adventure, batteries crapped out and we spent 14 daze on the Honda. 😂👎
Stream HAPPY...
W. H. Auden
Amanamus
"Tahawus"
Old 11-20-2018, 08:05 AM   #13
Half a Rivet Short
Hi
If you are going from one battery to two batteries, both of the pair need to be same / same. Put another way, you need to dump your old battery and get a pair of new ones. That way they will work properly together. You don't want one supplying all the power while the other just sits there.
The same thing applies to battery cables. If you are going to see heavy loads (like an inverter) you want to pull current equally from both batteries. That works best if you have the same cables to each battery. If the cabling is un-equal between the batteries, one will supply more of the load than the other.
In either case, you wear out one battery a lot and the other loafs along. Sometimes the hard working battery takes out the loafer and you get a real mess. Of the two, having the two new batteries is by far the most important. Do the cabling as best you can and accept that things are not quite ideal ...
Make sure that any added cables are at least as big as the combined cross section of whatever they are attaching to. AS runs separate cables to the inverter and this can fake you out ....
Old 11-20-2018, 08:05 AM   #14
2019 22' Sport
Stream HAPPY...
Thanks!
I guess models vary enough that installs could be quite different.
I surmise I have to be spliced into the lead directly from the battery.... I can't splice at the converter even if there is a solid negative lead at it. (I have just done a quick peek so far just to determine ease of replacement)
My original is August 2018 and new one factory fresh and I was told close enough. They are Lifeline AGM GPL-24T
I bought the second battery and Wildkat from best converter and trust they are a good match.
Reading up on the Victron elsewhere I read of some issues with a parasitic load that drained batteries in short order. I quote: "...however it does not measure the power which the gauge consumes on its own and it will consume every last amp left in your battery until it is completely dead and unusable." He went on to state and include photos of Victron indicating 100% battery but a gauge at the battery at 30%. The 30% was accurate as he could not turn over his vehicle. Went on to say it was left in "idle mode" which sounds like ON to me as opposed to OFF! Is there an option to turn it OFF so no battery drain?
Thanks!
Rounder44
Aka
Warren
Victron BMV 712 setup wareaglewalt Batteries, Univolts, Converters & Inverters 12 03-06-2019 06:05 AM
Victron BMV-712 panel lights turn off? marter Batteries, Univolts, Converters & Inverters 7 08-18-2018 11:37 PM
Question regarding Victron BMV-712 billrector Batteries, Univolts, Converters & Inverters 26 05-30-2018 03:21 PM
victron BMV-712 with battery temp probe waninae39 Batteries, Univolts, Converters & Inverters 1 04-23-2018 07:53 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
