Old 09-04-2019, 09:57 AM   #21
2019 22' Sport
Malibu , California
Getting ready to install in Sport 22 (no inverter). Correct that I can connect negative cable from battery to the shunt and then buy short battery cable from shunt to buss as long as at least same gauge as OEM cable?
Garfish is offline   Reply With Quote
Old 09-05-2019, 08:56 AM   #22
Half a Rivet Short
Carlisle , Pennsylvania
Hi
As long as there is only one cable leading away from the battery negative, matching the gauge of that cable is fine. If at some point you plan to put in an inverter then the cable would need to be a bit bigger.
Old 09-06-2019, 09:20 AM   #23
waninae39's Avatar
2017 22' Sport
NCR , Ontario
use the same or larger cable.
close to battery as possible.
dielectric grease on all connections
crimp each connector with a hydraulic crimper
waninae39 is offline   Reply With Quote
Old 09-08-2019, 05:47 AM   #24
2016 25' Flying Cloud
z , Texas
Originally Posted by Jimbob24 View Post
U need to install as close to battery as possible if. It directly to neg pole. My batteries are in parrallel so see pic below.
It is a multi hour job to put it anywhere else than directly to battery (per the am solar guys) so I just weatherproofed it and hooked it up and left in the battery box. Works sweet. But if you hook it up wrong the info wonít be accurate as far as time remaining , amp draw, etc
My batteries are connected just like yours, but I put my shunt inside my TT , my question is should I move the inverter wire from the negitve of the of the most positive battery too the negitve of the most negative battery,
5150mike is offline   Reply With Quote
Old 09-08-2019, 07:23 AM   #25
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
No, your inverter wire should go directly to the supply side of your shunt, the same side that is connected to your negative bus bar. There needs to be only one wire coming from the negative side of the batteries to the input side of the shunt, nothing else.-- Frank
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 09-08-2019, 06:59 PM   #26
z , Texas
Now I am confused, I have 2 negative wires coming from my batteries, one goes to the inverter and one goes to the negitve bus bar, I have spliced both wires and they now both run through the shunt, is this not correct?
Old 09-08-2019, 07:22 PM   #27
Half a Rivet Short
Hi
The two negative wires should go to the "bottom" of the shunt. The "top" of the shunt goes to the batteries and only to the batteries. Any other random wire that happens to be connected to the battery negative and lead off somewhere else (it's Airstream ..... who knows ....) also needs to go to th e"bottom" of the shunt.
Old 09-08-2019, 07:29 PM   #28
fran&frank's Avatar
So If I understand you correctly you have two wires coming from the negative side of your batteries to the input side of the shunt, then on the output side of the shunt one wire going to the negative bus bar and one going to the inverter? If so thats actually OK. Having two wires from the battery to the input side of the shunt is redundnant, but if single wire is undersized maybe the two are better. Bottom line is the only thing connected to the negative side of the battery is the shunt, everyting else comes off the other side of the shunt.
Frank & Fran
Equalizer Hitch
Old 09-08-2019, 08:50 PM   #29
z , Texas
Yes that's how I have it connected, my original question was should both negative wire at the battery be connected to the same battery? Because mine are notClick image for larger version
Old 09-08-2019, 09:39 PM   #30
waninae39's Avatar
2017 22' Sport
NCR , Ontario
its much easier to mount everything on plywood, pre wire as much and them mount
here is my initial plywood mount under the bed facing road side
pre and post
Name:	solar-lion power layout ready for install v4.jpg
ID:	351733   Click image for larger version
Name:	all installed item mounted to plywood board before install.jpg
Old 09-09-2019, 04:33 AM   #31
z , Texas
Wow looks awesome, wanna come do mine!!
pre and post
Old 09-09-2019, 09:23 AM   #32
Half a Rivet Short
Hi
The shunt setup would be every bit as accurate if you had a 100' long cable between it and the battery. Cable length does not impact accuracy. A 1 foot vs 4 foot cable is no different than having one more foot run to the load in terms of efficiency. If you take a look at the stock install of the inverter cable, shortening that up would be a much higher priority than anything you might do with the cable to the shunt.
Bottom line: No, the shunt does not have to go "as close as possible" to the battery negative.
Old 09-09-2019, 09:38 AM   #33
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i agree, small changes don't matter much
try to use as large a cable as you can
as 12v is low voltage and losses are the square of current, you want to keep the cable resistance low
Old 09-09-2019, 11:00 AM   #34
gator.bigfoot's Avatar
KW , Ontario
See this excellent article
https://marinehowto.com/installing-a-battery-monitor/
gator.bigfoot is offline   Reply With Quote
battery monitor, bmv-712, shunt, victron
Victron BMV 712 in battery box Bradley G Batteries, Univolts, Converters & Inverters 18 09-28-2019 07:32 PM
BMV-712 Battery Monitor Temperature Sensor billrector Batteries, Univolts, Converters & Inverters 2 12-18-2018 10:04 PM
Victron BMV-712 Install Question Rounder44 Electrical - Systems, Generators, Batteries & Solar 25 11-23-2018 05:53 PM
victron BMV-712 with battery temp probe waninae39 Batteries, Univolts, Converters & Inverters 1 04-23-2018 07:53 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
