Old 03-05-2016, 08:19 PM   #1
jhart657's Avatar
2007 25' Classic
1993 21' Sovereign
Elm Grove , Wisconsin
Victron Battery Monitor with Bluetooth connection to smart phone
I am interested in adding a battery monitor to my 25ft. Classic Limited. I just read some information about the new Victron BMV-700 Monitor that works in conjunction with a Bluetooth Smart Dongle. The Dongle wirelessly sends very complete information to your Android or IOS phone. Victron has a stellar reputation in the marine community making first rate charge controllers, inverters, and monitors. Has anyone had anyone had any experience with this set-up?
The installation itself looks very similar to the Trimetric. Everything is measured via a shunt. The monitor is attractive, easily mountable & taking little space. Price is competative.
Many of Victron's charge controllers and inverters also can be wirelessly monitored. It looks like programming of the various components is made easier through the use of the smartphone.
Any thoughts on this new approach?
Juergen
jhart657 is offline   Reply With Quote
Old 03-05-2016, 09:27 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Juergen
Juergen,
We (AM Solar) are about to go deep with Victron components. Check back in a couple of weeks when we have finished our orientation sessions. Great stuff!!!
Old 03-05-2016, 10:15 PM   #3
2015 30' Classic
Pleasanton , California
If the Victron BMV-700 already comes with a display unit, then what practical value is there to adding Bluetooth? I can see the need if you could save money on the display and only use an app, but if you already have a display unit, do you really see the incremental cost for adding this feature worthwhile?
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-05-2016, 11:05 PM   #4
ModernVista's Avatar
2016 28' International
Los Angeles , California
I have used victron bmv 700 on two units and am very happy. Never tried the Bluetooth connection, but recommend them otherwise!
Chris
ModernVista is offline   Reply With Quote
Old 03-06-2016, 11:12 AM   #5
2011 23' FB Flying Cloud
2008 19' Safari SE
Brossard , Quebec
Bmv-700
Few months ago, I was involved in a Victron project consisting of: LFP battery, solar panels, MPPT controller and 2000 W MultiPlus (transfer switch-inverter-converter) BMV-700 and CCGX control panel. The connectivity to smart phones is able via the VEDirect bus of these devices. The Bluetooth smart dongle of this project will be install this spring. I personally purchased the BMV-700 that I will install later this year. This device comes with the VEDirect port. In the project that I was involved the BMV-700 works flawlessly and the user is enthusiastic about it. And the selling price is quite attractive. When the dungle will be install I will you keep posted.
Michel
Papou is offline   Reply With Quote
Old 03-09-2016, 08:41 AM   #6
Plasma800's Avatar
houston , Texas
sounds interesting to me! Lewster, I'd be interested in more info!
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 03-09-2016, 09:08 AM   #7
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
I have used the Victron BM700 on my boat for about 3 years. It gives loads of info, and works. You will need to use their shunt as it has a plug and play receptacle on it. Never used the blue tooth feature.
It's the small gauge bottom right. Sure does have a lot of info.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 03-09-2016, 04:49 PM   #8
lewster's Avatar
Stay tuned. Should be a couple of weeks.
Old 03-09-2016, 06:32 PM   #9
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
A friend of mine just installed their stuff, and I'm extremely jealous now.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-09-2016, 07:22 PM   #10
lewster's Avatar
NICE!!! based on the size of your AC and DC panels, you must have quite a 'boat'.
Wait 'till you see Victron's new OLED display. Not sure if it's out yet, but it is a work of art!!!
Old 03-09-2016, 08:05 PM   #11
2015 28' International
Ofallon , Missouri
I'll be watching! Definitely about to invest in a battery monitor. Have studied Trimetric vs battery check wireless. I found several negative reviews about the battery check reliability of the wireless connection. I think BT has limited range? Unsure of ability of BT to go through material like alum skins. Was about to pull the trigger on Trimetric but will now hold off for a bit.
mpsgolf is offline   Reply With Quote
Old 03-09-2016, 08:14 PM   #12
2006 25' Safari
Thanks, Lewster. That little Victron SOC meter gives more info that all the other stuff there. As you know basing the SOC on voltage indicated is just a guestimate. The Victron gives the SOC based on amp hrs depleted.
Bold, that is a nice setup. I have no solar other than an 80 watt portable panel. My charger bulk charges at a little over 14 volts. 13.3 volts is the float charge rate. I was just wondering why 13.28 is considered the bulk rate on the solar charge controller panel.
I am learning about solar here. I would like to add some to my AS.So, please keep posting as I think several are following along.
Don
'06 Safari 25 LS
Old 03-10-2016, 05:25 PM   #13
2008 19' Safari SE
Brossard , Quebec
Pictures bmv-700
For your information, here is some pictures of my BMV-700 (front and rear)
The small square white connector at the back is the VEBus port.
The green phoenix connector is the Dry contact relay output, and the round "barrel" is the programmable "Sonalert" unit.
The connectivity between the shunt ant the BMV is a Cat-5 cable.
There is also a small red cable (not shown in the picture) that plugs on the battery plus side for powering the system.
All these are provided in the package
Michel
ID:	258542   Click image for larger version
Old 03-11-2016, 08:43 AM   #14
Brav's Avatar
2016 25' International
Huntington Beach , California
Very nice to hear. I have been studying Victron products and will likely use them when I save up enough for my power / solar upgrades. What about using their color display? Color Control GX
2016 International Sig 25FB
2010 LR RR S/C
Brav is offline   Reply With Quote
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
Kenwood DNX7180 Bluetooth phone issue BobOhio Sprinter and B-van Forum 6 05-13-2014 11:19 AM
New Smart Phone App to measure vibration perryg114 Tires 0 07-29-2012 12:16 PM
Smart Phone/Pad Apps RoadJager Sprinter and B-van Forum 7 06-24-2012 07:36 PM
Bluetooth Internet Connection? Lee Davis Full-Timing 10 05-18-2006 11:36 AM
