Old 05-12-2006, 09:09 PM   #1
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
Vented Battery Box
Our '68 Tradewind has the battery in the original location: under the midship bed. We have been to several RV and boat stores looking for a sealed and vented battery box with zero success. Any ideas where to find one and, if there is one, perhaps one with an aluminum shell-side termination fitting?
Thanks in advance . . . these forums are a great source of information, knowledge and humor. I could spend hours reading through some that have nothing to do with our current "projects"; in fact, I do.
By the way, what's with the rivets? Are they earned, bought, bartered for or granted by a Higher Authority?
Neophyte is offline   Reply With Quote
Old 05-12-2006, 09:38 PM   #2
Darol Ingalls's Avatar
Your original battery holder probably had a plastic cap affair with a vent hose that was supposed to vent the fumes outside through a small, screened fitting. Those caps usually broke after a few years and were discarded. I've made battery boxes of plywood and vented them outside on some trailers, but I've since discovered sealed batteries, either gell-cell or the glass matt absorbtion type. These can be placed anywhere inside and don't need to be vented. Much easier than trying to install a battery box and make it waterproof to the exterior of the shell. They may cost a little more, but compared to the cost of a new box and the limitations of placement, I think they are the best bet. As for the "Rivits", they are a mystry. Darol
Darol Ingalls is offline   Reply With Quote
Old 05-12-2006, 09:53 PM   #3
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
Thanks for the prompt response.
But if the "Rivits" are a mystery, how'd you get three of them?
Old 05-12-2006, 09:55 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Neophyte,
The rivits are given based upon the number of posts. The formula is somewhere on the forum.
Bill
Just my personal opinion
Old 05-12-2006, 11:20 PM   #5
1960 24' Tradewind
santa barbara , California
Hello neophyte,
Summit racing products sells a special battery box that is designed to be closed with a lid ,comes with it ,made of heavy polypropelene plastic material.
it has vent hoses as well .Its made by MOROSO ,you can go to SUMMIT RACING online to locate it .Only problem is that it is expensive.
Scott
scottanlily is offline   Reply With Quote
Old 05-13-2006, 05:39 AM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Any boat or marine store such as West Marine or Bass Pro Shops will have them. Check a local dealer that sells boats, too.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-13-2006, 08:01 PM   #7
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
Pick,
Those were my two stops on my first time out searching; Bass Pro & West Marine are across the parking lot from each other in a strip mall 10 minutes from the house. No luck so far but thanks.
Beginning to look like home-made or gell-cells. Too bad I have a brand new battery to replace.
Old 05-13-2006, 08:54 PM   #8
Images: 59
Here's one:
http://www.pplmotorhomes.com/parts/r...xes-vented.htm
and here are some more:
http://www.alliedbattery.com/boxes.htm
Allied has more sizes, but you need to add hoses.
Old 05-13-2006, 09:33 PM   #9
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
My humble thanks
Mark,
You're the MAN!
Thanks. It is people like you that make these forums great.
I tried a variety of google searches and didn't find what you sent me. Thanks.
Old 05-13-2006, 09:36 PM   #10
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
Mark, the smilie that got posted was NOT the one I selected - honest. I was trying for "punk". (so much for trying to be cute)
Old 05-14-2006, 05:39 AM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Ah, I see what you are looking for, now. Most battery boxes are "vented" but not to the outside of the coach.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-14-2006, 08:23 AM   #12
aztlanco's Avatar
El Paso , Texas
Send a message via AIM to aztlanco
You might try the R.V. salvage yards also. Some of the older trailers had sealed poly boxes that had an access door to the outside that had louvers or vent holes.
Ernie
1958 "Traveler" 18ft.
aztlanco is offline   Reply With Quote
Old 05-14-2006, 09:43 PM   #13
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
Azlantco,
That is one sweet AS! What's the frequency between buff-outs?
Old 05-14-2006, 09:54 PM   #14
aztlanco's Avatar
El Paso , Texas
Rivet
Azlantco,
Thanks Mick,,,
Gets buffed once a year. Its not hard to keep up the polish after the initial 1st time.
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Second Battery w9det 1999 Safari 5 12-06-2002 06:42 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 06:37 PM
61 Bambi Battery 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 05-21-2002 10:53 PM
