Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-30-2009, 08:15 AM   #1
'71 Overlander Land Yacht
Ag'71's Avatar
Profile:  1971 27' Overlander
Springfield , Missouri
Vent Fan Wiring
Hi, I'm a newbie here with a '71 Overlander. While cleaning my ceiling vent fan, I didn't take note of the wiring of the switch. Does anyone know how to wire the switch. There is a brown and red wire from the trailer and three poles on the switch. What goes where?
Thanks.
Ag'71 is offline   Reply With Quote
Old 09-30-2009, 09:10 AM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you have a volt meter one of the wires should have 12 volts on it and the other should go directly to the fan.
The switch may be marked. Com, NO, NC. If you see these markings put the hot wire on the Com and the other wire on NO.
The markings indicate Com common NO normally open, and NC normally closed.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 09-30-2009, 09:19 AM   #3
Ag'71's Avatar
Thanks! I'll check it out.
vent fan Judy Barde Roof Vents, Skylights & Fans 2 06-02-2008 10:06 PM
A/C Fan wiring PhilMateo Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-25-2006 03:06 PM
Sure Line Vent Fan Chaplain Kent Roof Vents, Skylights & Fans 1 03-31-2006 10:07 PM
vent fan wiring joel Electrical - Systems, Generators, Batteries & Solar 3 07-06-2005 10:10 PM
??wiring/lighting/fan???? tin can luv Electrical - Systems, Generators, Batteries & Solar 8 04-19-2004 03:35 PM
