Old 05-29-2005, 07:37 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Using Satellite tv
I have Direct Tv at home, and really like it. My batwing TV antenna on the MoHo leaves a bit to be desired, especially in the mountains where we camp often.
My questions are-
If I take my Direct tv receiver with me, how do I find the satellite for reception? Should I buy one of those little sat finders?
Isn't the actual dish itself and LNB for Dish Network and Direct Tv the same, just the receiver varies? The reason for this question is I have a Dish 500 large oval dish and LNB that I could use, needing only the tri pod stand, but as I said above Direct Tv is my provider at home so I would use that receiver.
I assume that with a little proper set up this would work?
Thanks for any insight into the RV satellite set up.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-29-2005, 08:09 PM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
My Direct TV retailer (who also sells Dish Network) told me that he would sell me a used sat dish on a tripod for $75.00. He says I can take this little dish anywhere and as long as I have one of my home receivers I can get sat TV in the trailer. I haven't tried it yet, but he says it will work if I have a clear view of the Southern sky with the sat dish. Sounds like a solution to me. Judy
juel is offline   Reply With Quote
Old 05-29-2005, 08:38 PM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Those little Sat finder meters work great. They cost around $30. They are worth the money in my opinion. Sure beats having to set up your receiver and TV right next to the dish to aim them. Yes, a Dish dish will work on DirecTV and vise versa.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-30-2005, 05:52 AM   #4
baldeagle's Avatar
Been doing it for a few years. Not so difficult with the "clear view". Can't get reception thru trees. Of course, the additional receiver must have a valid (read monthly fee) card. Have fun. The setting up is well worth having DirecTV on the road.
baldeagle is offline   Reply With Quote
Old 05-30-2005, 07:22 AM   #5
Cracker's Avatar
Pittsfield , Maine
Another vote for the sat finder meter! Too much frustration without it. The sat reception meter on the TV screen doesn't seem to respond fast enough - and by the time I locate the sat my wife is ready to divorce me!
Cracker
Cracker is offline   Reply With Quote
Old 05-30-2005, 07:45 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks. I will get that meter. Sounds easy and I know it will be worth it if only for the music! My extra home reciever is easily disconnected for road use.
AIR #005
retired!
Old 05-30-2005, 08:52 AM   #7
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I have been using it for about 4 years and have been very happy. The extra reciever that I have costs me $5.00 a month. When you get to your site you just turn on the reciever and plug in your location zip code, the tv displays your compass direction and dish angle. Don't even try it without the meter unless you have more patience than Job. It can work and it will work without it but the older I get I find that I have less tolerance for pain.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 05-30-2005, 02:23 PM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I bought the meter, and next I will buy a tri pod so I should be all set.
AIR #005
retired!
Old 05-30-2005, 04:25 PM   #9
Wink A few more answers please
Whats a LNB?
Are we certain about the same Dish and LNB working with either reciever?
I see the dishes in the garbage all the time, guess when customers switch from one to another, the install crew throws out the other. If the other would work, why would they throw it out???
Is it possible to buy the thing that you are charged $5.00 a month for?
Or is that a user fee?
If I just unhook my main home reciever and take it on the road, do I need to pay the $5.00 fee? Does the satalite know Im not at home? does it care?
How do you get the zip or area code of your location out in the boonies?
And is there a decrease in quality of reception if the coax run from the dish to the reciever is very long? Any idea of what is too long?
Also I have heard that a particular type of coax is required (not plain old cable tv coax) Is this true?
Flicka
Hit'nMiss is offline   Reply With Quote
Old 05-30-2005, 04:41 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
-the dishes are the same as I have had confirmed. I bought mine at Goodwill for 3 dollars with two LNbs on it and lots of coax. The LNB is the little receiver thingie( so technical!) that points at the dish, its white plastic covered.
-The only reason to know the zip code is so you can manually enter the satellite configurations or use the auto set up. As I now understand it you can use the sat finder meter to do thst instead, and then just point it at the sat and let the guide set itself up for programs. The finder takes no time to get the signal.
-The second home receiver is five dollars extra over the inital charge per mo, I pay $41 for both with local channels and no premiums, but lots of tv channels and music channels.
-The reduction in reception is supposed to be minimal until you get really long on the cable distance. You can use a heavier coax to eliminate that issue. I have heard 50-70' is no problem.
I'm new to the mobile part, but have had satellite at home for five years, its terrific. I only lack the DVR to make my system perfect for us. (TIVO)
AIR #005
retired!
Old 05-30-2005, 07:09 PM   #11
Tarheel's Avatar
Images: 21
The biggest thing about manually setting the dish is to know the angle. There are 3 satelites at almost the same location. I was told and its the procedure I use, is to set the angle first, somewhere close to 30 degrees for me with dish net in North Carolina. I then swing it slowly at the compass heading, somewhere around 240 degrees. When I get a good signal I slowly move it back and forth to lock in the best compass heading. Then I adjust the angle to get the best signal. This works for me. Cloudy days and trees can overcome technology. I carry about 100' of coaxial so that I can look for a hole in the trees if need be. If your neighbor has the same system you can split his signal and leave you dish in the truck. That's one advantage of traveling with friends.
WBCCI # 348
Old 05-30-2005, 07:48 PM   #12
Send a message via Yahoo to Boats13
Cable differences....
The older smaller cable will be labeled with various letter combinations... however the numbers "59" will be on the cable along the length a regular intervals.
On the newer cable it will have a "6". 6 cable is used on all the newer installations for digital and data carrying applications.
I do not know what these numbers signify, perhaps a metric diameter of the inner parts(minus the cover) maybe?
Our paperwork (and installer) stated that 120ft of reach was fine without signal drop.
CT
Boats13 is offline   Reply With Quote
Old 05-30-2005, 09:03 PM   #13
Tikihut's Avatar
1977 Argosy Minuet 6.0 Metre
schaumburg , confusion
Send a message via AIM to Tikihut
the cable you are refering to is RG59 and RG6.
Tikihut is offline   Reply With Quote
Old 06-01-2005, 04:45 PM   #14
baldeagle's Avatar
I used my main home tuner on the road for a few years. No extra fee.
Satellite TV help Nick Danger Electrical - Systems, Generators, Batteries & Solar 11 01-07-2005 11:55 AM
Satellite Antenna Don in E Texas Electrical - Systems, Generators, Batteries & Solar 2 04-25-2003 03:57 PM
Satellite from above 53flyingcloud Our Community 14 03-29-2003 09:46 AM
Satellite Question davthr Our Community 11 03-17-2003 11:31 AM
Satellite Equipment rdm Airstream Motorhome Forums 7 03-14-2003 10:00 AM
