Old 11-22-2015, 07:17 AM   #1
2015 Interstate Grand Tour
kirkwood , Missouri
Using aux TV batteries to charge AS?
We tow a 2010 AS International 27fb full time with a Nissan NV. We have solar, 300watts on top and 2 lifeline AGMs (300amphr) under the bed. The NV has factory wiring to add an auxiliary battery in the rear. Is it possible to add 2 more lifeline batteries to the rear of the NV which would be charged by the NV alternator to supplement our AS battery bank?
We do plan to add more panels as well.
epicdetour is offline   Reply With Quote
Old 11-22-2015, 07:30 AM   #2
mandolindave's Avatar
I'm underwhelmed by TV ability to charge batts
You might be better off adding more batts to the trailer, but since you want the same circa batts, I was thinking about hooking up an additional bank of batts with an A/B battery cutoff switch
Moot point for me as my 9 year old AGMs are done. So I'll be moving up from 2 to 3 batts.
You kinda have to use AGMs for more than two batts because venting that many would be a pain
mandolindave is offline   Reply With Quote
Old 11-23-2015, 05:08 PM   #3
kirkwood , Missouri
Thanks Dave! We don't *want* to add more batteries to the AS due to weight and space issues (even tho we'd be adding same said weight up front). The most interest we have is how to use the NV alternator to charge a TV battery bank that can supplement the AS batteries. Anyone?
Old 11-24-2015, 07:19 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
You'll need either a DC to DC charge controller or a battery isolation manager (BIM) like the one from Precision Circuits that are used on the Interstate vans.
Simply connecting AGMs to an alternator will eventually over charge them.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 11-25-2015, 06:28 AM   #5
kirkwood , Missouri
Lew Farber
541-490-6357
Thanks Lew! I'm glad to see your input here!
So if we can control the charge coming in to the agm's in the TV, what would be the best way to get the charge from the TV to the TT and into those batteries?
Old 11-25-2015, 06:44 PM   #6
lewster's Avatar
I see 2 ways, though there may be others:
swap them out with the depleted ones in the trailer when needed
make up the required length of very heavy welding cable (length dependent) terminated with Anderson connectors for plug/play use.
A third option would be to use option 2, but add a 2 position marine battery selector switch into the mix. This will actually combine both of the first 2 options without having to physically move the batteries.
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Charge wire on 7-pin, what demands does AS need and how does this charge starcraft Batteries, Univolts, Converters & Inverters 10 04-20-2012 08:38 AM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
Limiting Charge Rate of Batteries campadk Batteries, Univolts, Converters & Inverters 11 01-28-2007 10:49 AM
Auxiliary batteries won't hold charge Lena Abbott Batteries, Univolts, Converters & Inverters 5 09-26-2006 06:36 PM
