Old 01-15-2020, 09:49 AM   #1
Jasper Ash's Avatar
West Palm Beach , Florida
Using a splitter on TV Inverter Circuit
Hello! Does anyone know if I can use an outlet splitter on the “Inverter Circuit” outlet behind the bedroom TV? The outlet only has one 120v outlet, the bottom outlet is sealed shut.
I assume this is to prevent the owner from using more power than the inverter can supply. But when hooked up to 50 amp shore power and not using the inverter, can a splitter work to power two devices?
I would like to plug an Apple TV in here and mount the unit to the back of the TV without having to run the Apple TV power cord across the bedroom to another outlet.
Jasper Ash is offline   Reply With Quote
Old 01-15-2020, 10:26 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
You can actually use a dremel tool or a small chisel to open up the sealed outlet. Or, you can replace the whole outlet with one that has both open, sold by many RV places. Make sure it is deenergized before you mess with it.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-17-2020, 08:40 AM   #3
Jasper Ash's Avatar
Thank you for the info. I might consider swapping to a dual outlet. But for now, I’m not sure I want to modify the existing outlet.
So for a temporary fix - is there an issue with using a splitter in the inverter circuit outlet when not running the inverter and connected to shore power?
2020 Flying Cloud 27FB w/ Rear Hatch
2017 Toyota Tundra SR5 Double Cab 5.7 FFV
Old 01-17-2020, 08:47 AM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It will not be a problem
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 01-17-2020, 08:49 AM   #5
eagletoo's Avatar
New Hyde Park , New York
Jasper,
No issue using a multi-tap to power your Apple TV from the TV outlet.
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
Airstream Club International #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 01-17-2020, 09:38 AM   #6
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
My 2012 25’EB has one of these electrical fixtures near the TV, one socket, the other closed off. What’s that about? Why and what’s it for, what’s it do? I never thought about it before this thread, now I’m interested.
brad1 is offline   Reply With Quote
Old 01-17-2020, 12:13 PM   #7
lsbrodsky's Avatar
I believe it was an attempt by Airstream to limit the amount of demand you could place on the inverter. Mine was exactly the same way, only one outlet at each location. Long before I redid my electrical system, I drilled out, then replaced those fixtures. But, I really never needed anything else plugged into the inverter socket since the inverter was so puny to begin with.
Larry
Old 01-19-2020, 08:33 AM   #8
Jasper Ash's Avatar
Thanks for the feedback, everyone! I didn’t find much on the topic when searching - probably because it’s such a non-issue. This is my first RV and Airstream so I’m being overly careful with everything.
Old 01-19-2020, 08:47 AM   #9
batman's Avatar
1964 22' Safari
modesto , California
The only concern would be the amount of current draw at the outlet, it should not exceed the output of your inverter.
Since you are new, Be aware of the inefficiency of using an inverter. They will suck the life from a battery supply in no time. Unless you are able to turn them off they still have a parasitic drain on your system.
-Dennis
batman is offline   Reply With Quote
HDMI Splitter Cable GerryH Audio, Video & TV 1 12-14-2011 11:26 AM
1983 Antenna System Splitter? jerry d Audio, Video & TV 0 07-09-2011 10:03 AM
TV Cable/Splitter Ugly1 All Squarestream Trailers 2 10-12-2009 12:23 PM
digital tv: splitter or amplifier? Chuck Audio, Video & TV 2 07-08-2007 04:46 PM
Cable Splitter jhobbs Electrical - Systems, Generators, Batteries & Solar 6 10-14-2005 11:02 AM
