Old 01-21-2015, 08:34 AM   #1
2015 27' Flying Cloud
maple grove , Minnesota
Using a 30A cord with a 50A shore power terminal
Has anyone found a supplier who makes a shore power plug for a 50 amp
circuit, which adapts to 30 amp. On my 50a flying cloud, I won't
be running 2 a/cs very often so I'd like to just use a 30 a cord plugged directly into the 50a shore power connector, assuming I can find the proper connector.
thebreezeman is offline   Reply With Quote
Old 01-21-2015, 08:49 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Try something like this. It's a 30 amp cord with a 50 amp female end that plugs into your 50 amp coach connector. A whole lot less wrestling with this cord than with a "real" 50 amp cord!
50 Amp to 30 Amp Adapter Cordset with Fault Smart LED - 25' - Furrion F50AR25-SB.AM - Electrical Adapters - Camping World
Bob Martel
WBCCI# 5766
Old 01-21-2015, 08:51 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Google and Amazon are excellent sources of information and RV products.
http://www.amazon.com/s/ref=nb_sb_no...30+amp+adapter
MICHAEL
Old 01-21-2015, 10:12 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
An adapter is readily available at Camping World or on Amazon. These adapters are necessary as some campgrounds have only 30 amp outlets and others have only 50 amp outlets. We carry a 30 to at all times.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 01-21-2015, 10:38 AM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Furrion also makes a female 50amp to two 30 amp male plugs pigtail. In some places there may be only a 30 amp outlet and a standard house outlet. Using a 30 amp female to 110Vac male plug and power goes to the trailer with 30amps on one leg and 20 amps on the other.
Old 01-21-2015, 10:51 AM   #6
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Use and adapter plug, easy and cheap.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 01-21-2015, 11:01 AM   #7
2020 Classic 33 on order
Box Elder , South Dakota
This is a 50A to 30A adapter from CampingW. Rather than another cord this allows you to use the current cable and if you have a surge protector then the SP would plug into the adapter and you should be good to go.
Name:	Screen Shot 2015-01-21 at 9.59.37 AM.png
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 01-21-2015, 11:34 AM   #8
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
You can buy an adapter cord at WalMart.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 01-21-2015, 12:01 PM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I think the op wants to not use the heavy, stiff 50 amp cord and use a lighter, more flexible 30 amp cord. He is wanting an adapter at the trailer to facilitate the use of the lighter 30 amp cord.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-21-2015, 01:57 PM   #10
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
That's what I was thinking too. Maybe something like this?? Amazon.com: RV Power Cord Adapter 30 amp Male TT-30P to 50 amp twist lock female SS2-50R: Automotive
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-21-2015, 04:27 PM   #11
1977 27' Overlander
Drummond , Wisconsin
This is an interesting thread. So if I am understanding correctly it is OK to plug a 30 amp AS into a 50 amp out let if you use an adapter.Is there a problem with using the AC or any of the other appliances?
Thanks, Reg
Reg Mary is offline   Reply With Quote
Old 01-21-2015, 04:41 PM   #12
Dallas Center , Iowa
Enjoy the journey!!
Earthcreeper is offline   Reply With Quote
Old 01-21-2015, 05:09 PM   #13
Charleston , South Carolina
Admittedly, I know just enough about electrical systems to be dangerous, but I do know from residential wiring jobs long ago that 30 amp is a 110 volt circuit and 50 amp is 220 volt. And I know that 220 volt is achieved at the service panel by utilizing two positive 110 leads and one neutral (plus ground for safety) and 110 volt only uses one positive lead. So, when using the 30 to 50 amp adapter, how does it achieve the required 220 volts?
FollySteve is offline   Reply With Quote
Old 01-21-2015, 05:15 PM   #14
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Here you go.
EEL Pigtail Adapter, 30A Male to 50A 125V Female | Marinco
This will connect to the trailer side 50A receptacle and allow connection of a 30A cordset with a twistlock load (trailer)end and a 3-prong line (RV park connector) end. West Marine stocks Marinco. if your nearby WM doesn't have it, they can order it. Also at Amazon. Not inexpensive.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 01-21-2015, 05:18 PM   #15
Slowpoke
Gnorts's Avatar
Portland , Oregon
Both the 30A and 50A connedctors being discussed here are 120V. There is no 240V on Airstream trailers.
Old 01-21-2015, 05:18 PM   #16
Be careful. There is a bit of difference between Marine vs RV fittings.
Gary
NØVPN
Old 01-21-2015, 05:22 PM   #17
Slowpoke
Gnorts's Avatar
Portland , Oregon
Thanks, Reg
Yes, you can do this. Just remember that, if you plug your 30A trailer into a 50A source, the 50A circuit breaker at the source will not protect your trailer; the 30A master breaker in the trailer's electrical panel will provide proper protection. The only portion of this setup that's at risk is the 30A cord between the trailer and the source.
Old 01-21-2015, 05:23 PM   #18
Hope I get this correct. In an AS that has 50amps in reality you have a split system. One leg of the 50amps/125V goes to circuit 1 and the other leg goes to circuit 2. Each circuit has one of the A/C units on it plus other 'stuff'. You can look at the manual or the CB panel to determine which devices/outlets are on each circuit.
Just an assumption since I don't have my Classic yet but the adapter pigtails must put power to both circuits. Limitation would be that you only have a total of 30amps across both circuits. Should be able to run everything except 2 A/C units at the same time.
And no 220/240 in the trailer as has been mentioned.
Gary
NØVPN
Old 01-21-2015, 05:29 PM   #19
Slowpoke
Gnorts's Avatar
Portland , Oregon
The twist-lock fitting at the trailer is a standard NEMA connector, which is also used on boat shore power cords. The three-pronged plug at the other end of the cord is also NEMA standard, but is not used on boat cords. Frankly, neither of these connectors is ideal for either marine or RV use, but the standard is well-established so that's what gets used.
fyi, NEMA: National Electrical Manufacturers' Association.
Also, fyi, there is now a new connector type that is approved for marine use. Also being marketed for RV use. Better, safer, also not inexpensive.
SmartPlug Systems - Shore Power Products and Accessories
Old 01-21-2015, 05:57 PM   #20
ottawa (greely) , Ontario
Your right on most of what you said ,( regarding house electrical )but the airstream is 120 volt and either 30 amp service or 50 amp service 120 volt . Never 220 volt in North Americans airstreams . (Im sure they make airstreams with higher voltage for other countries.)220 volts will damage the electrical system in the trailer and any component pluged in to outlets plugs.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
2015 50A Power Cord Stiff and Near Unusable 2012FB 2009-2015 Flying Cloud 35 01-09-2015 05:34 PM
50a AS at a 30a campsite bunni Electrical - Systems, Generators, Batteries & Solar 4 09-02-2013 07:05 AM
Any idea where I can find a short 30A cord for generator use? barrettjl Electrical - Systems, Generators, Batteries & Solar 18 11-01-2012 01:02 AM
30A to 50A cord? Bambi_Bandit Electrical - Systems, Generators, Batteries & Solar 9 02-04-2009 04:57 PM
30A Upgrade to 30A + 20A Wayne Olson Classic Motorhomes 10 12-12-2006 04:51 PM
