Old 01-25-2015, 06:18 AM   #43
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
50 Amp Shore Line Readings
50 Amp Connection.002 by Fantinesvoice.com, on Flickr
It would appear that what goes in to the Airstream from a 50 Amp shore line is 120v on each side and when read across the two hot poles, 240v. This is correct as the connection was running my moho for three years, reads as correct with my line monitors, and has given no problem. I would therefore have to conclude my 50 Amp to 30 Amp configuration as shown in the earlier photo, is indeed correct.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-25-2015, 08:04 AM   #44
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
50-amp adaptors
These adaptors cover all the bases for my 50-amp wired Airstream. I stay with the pudgy 50-amp cord to reduce clutter, overloads and line loss. And a surge protector heads it all up, which is a whole other topic.
JBinKC is offline   Reply With Quote
Old 01-25-2015, 10:36 AM   #45
2016 30' Classic
Erie , Colorado
Here's a nice review of the setup. Easy to understand the 50 amp with its two legs. Also if you look at the 2014 AS owners manuals you will see usually 8 sub breakers, 4 on each side of the two 50 amp CB's in the middle. Easy to understand what is on each side.
FTLS - Electrical Distribution
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 02-08-2015, 05:49 PM   #46
Msmoto's Avatar
2007 25' Safari
Images: 135
Test of new cord
Originally Posted by Msmoto View Post
I have a 30 Amp Cord to which i have spliced in a 50 Amp female plug so i can directly hook up the trailer to my generator without the cumbersome 50 Amp cord, which i find a bit overwhelming. And, when I have my new cord plugged into a 50 Amp shore receptacle, here is what I get for readings. My query is: Have I done this correctly....experts?
Airstream_50_Amp_Receptacle to 30_Amp_Cord.001 by Fantinesvoice.com, on Flickr
So, after checking all the info I could, and very helpful was the post by ghaynes755, I hooked up the 30 Amp male plug into my 4000w generator, the the 50 Amp end into the Airstream receptacle, and obtained 14.4 v, and the a/c ran well, switching between front and rear to do a complete test.
As noted in the excellent article "FTLS - Electrical Distribution", when on 30 Amp it is running the entire 30 Amp over both legs of the electrical circuit.
So, the test went well, the generator running bout two hours with no problems.
AIR #31871 K4MTL
Old 02-08-2015, 07:12 PM   #47
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I use a similar set up but with two 2000 Honda's running in parallel. As you noted runs one A/C at a time, which is fine. If I just want to hit the batteries I run only one to charge them up if the solar is not doing the job.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
2015 50A Power Cord Stiff and Near Unusable 2012FB 2009-2015 Flying Cloud 35 01-09-2015 04:34 PM
50a AS at a 30a campsite bunni Electrical - Systems, Generators, Batteries & Solar 4 09-02-2013 06:05 AM
Any idea where I can find a short 30A cord for generator use? barrettjl Electrical - Systems, Generators, Batteries & Solar 18 11-01-2012 12:02 AM
30A to 50A cord? Bambi_Bandit Electrical - Systems, Generators, Batteries & Solar 9 02-04-2009 03:57 PM
30A Upgrade to 30A + 20A Wayne Olson Classic Motorhomes 10 12-12-2006 03:51 PM
