Old 04-11-2017, 05:35 PM   #1
Parker , williamdcrockett
Use/Store switch with Solar
I installled enough solar power to charge the batteries on my 27' FB without using the converter when hooked to shore power. I have 360 watts going into an MPPT controller with the correct size wire going from the controller directly to my batteries. I have been using the use/store switch by the door to set the system to store mode when I am camping with shore power because my converter does not have a 3 stage charger. Over the last 18 months two solenoid switches have failed while camping so that I had no power and was stuck in store mode when boon docking. Each time I jumped around the solenoid to get power from the batteries to the trailer so that I could continue camping. When it happened the first time I figured any switch can fail and replaced it with a new one. When it happened a few weeks ago for the second time I decided to take the solenoid apart to see if I could repair it. When I started to remove it I notice it was really hot and as I tapped on it it switched from store mode to use. So I went back to the switch by the door and checked it several times toggling back and forth from store/use with and without shore power. Now the switch and selonoid are working fine. So.... is it possible that having solar wired directly into the batteries by passing the converter is damaging the solenoid switch? I would rather not have to buy a new converter because my solar keeps the batteries topped without any charge from the converter. But it seems strange that I have had two events where the solenoid failed and this last time the solenoid was over heating. Have any of you guys had issues with the solenoid on you AS trailers?
wcrockett is offline   Reply With Quote
Old 04-11-2017, 05:39 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
I seriously doubt it! every one of my solar installations are wired so tha the output from tha MPPT solar controllers go directly to the battery terminals....as they should!
I also leave the use/store switch in it's original operational mode and have never had any reports of solenoid issues.
Best to look elsewhere for your solenoid issues.
Old 04-12-2017, 02:52 PM   #3
2016 30' International
redondo beach , California
You replaced the relay more than once and a wiring error would not likely be intermittent
The only thing left is an intermittent use/store switch causing the latching circuit to fail, or a loose wire in the latching circuit.
A guess.
RC
mythbuster88 is offline   Reply With Quote
Old 04-27-2017, 12:58 PM   #4
What ever happened to the mystery of the relay solenoid??
Old 04-27-2017, 01:16 PM   #5
2007 22' International CCD
Please note that the standard use/store relay is mechanically latched. There is no electrical circuit to 'hold' the relay...
Internally the relay as a spring that holds the contacts closed when it is latched to the 'use' position. Its a clever mechanical design.
rmkrum is online now   Reply With Quote
Old 04-27-2017, 01:20 PM   #6
Another thought. The standard relay only needs to have it's coil momentarily energized to latch or unlatch it.
If the switch by the door has a sticking issue, that would explain the relay coil getting very hot.
Look into the condition of the use/store rocker switch on the panel near the door. If it is getting stuck in one position or the other for any length of time it will surely overheat the coil and cause it to burn out eventually...
Old 04-28-2017, 07:06 AM   #7
Thanks. The switch by the door was sticking. In the future I will make sure it returns to the nuetral position.
Power outage while on batteries (Flipping use/store switch restored power) TwoSporks Electrical - Systems, Generators, Batteries & Solar 11 12-13-2016 11:06 AM
Use/Store switch, clarification when using shore power. crazylev Electrical - Systems, Generators, Batteries & Solar 10 08-05-2016 05:19 AM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Store/use switch and charging B25guy Electrical - Systems, Generators, Batteries & Solar 21 07-05-2010 02:52 PM
"Store-Use" SWitch Rleirer 2003 Safari 10 04-17-2003 02:07 PM
