Old 08-02-2016, 01:47 PM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Use/Store switch, clarification when using shore power.
Hi all.
I'm wondering if you could double check my procedure using the USE/Store switch, and then connecting to shore (AC) power. I just want to make sure I haven't gone insane:
Arrive at storage place to load up trailer, I switch the trailer USE/Store switch to USE, red light on.
Hook up AS to car, get to campsite, pull out generator (or plug into provided shore power). Plug into power source, and done. I don't do anything else with USE/Store switch until returning to storage, then switch to Store before departing.
Is this correct? What I am wondering is once you plug in the trailer to shore power or generator, you don't have to press the USE button again, correct?
And assuming that this correct, when plugged into shore or generator, batteries should be on a slow continuous charge from converter, right?
Just want to make sure this is right since I started another thread and been going crazy trying to figure sort some issues out. http://www.airforums.com/forums/f37/...ml#post1829929
Thanks for your help.
JL
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-02-2016, 02:32 PM   #2
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
You are correct. It is just a 12v disconnect so leave it on when in use.
cliffcharb is offline   Reply With Quote
Old 08-02-2016, 02:43 PM   #3
2007 22' International CCD
The only peripheral issue is that the original built-in battery charger (convertor) in an Airstream tends to incorrectly charge the batteries.
You can manage this by regularly checking and refilling the batteries, or replacing OEM cheap one with a better convertor. That subject has been beaten to death on the forums time and time again. Search and read a few knock-down drag out threads on the subject....
Personally, having just discovered that my stock convertor has again fried a nice new set of heavy golf cart batteries, I'm going to get off my butt, do it right, and install the new convertor first, then replace the fried batteries.
I am an experienced design engineer, but sometimes I irritate myself...I know better, but don't always have time to do better. That's my story, and I'm sticking to it. 😀
Old 08-02-2016, 02:47 PM   #4
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Thanks guys.
My original Parralax? converter died a few years back and I replaced it with a 3 stage converter from BestConverter.com. Seems fine but with my current issues not sure what is going on.
Old 08-03-2016, 01:15 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You are good to go then...we have replaced our original converter with a 3-stage as well... We leave the "use/store" switch on all the time, even when on shore power or generator. We store ours at home and plugged into 30-amp service so it's always on ... The only time we put it in "store" is if we are off shore power and want to cut power to the rig... like when we are leaving it at a service center for a while and don't want to batteries to run down while sitting there ...
TB & Greg and Abbey Schnauzer
#3954
Old 08-03-2016, 06:20 PM   #6
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Don't forget that when you place the Use/Store switch in the "Store" position the LP Gas Detector/Alarm is still drawing power (about 90 mA) and the batteries are not being charged. This is not a large drain but if storing over 2+ months I would recommend disconnecting the battery cables. Plus that way if the towing brake-away lanyard gets accidently pulled while in storage your electric brakes will not engage.
BoscoMN is offline   Reply With Quote
Old 08-03-2016, 06:28 PM   #7
CruizinDux's Avatar
Tracktown USA , Oregon
The stereo may also be a parasitic draw. It is on our '14 FC20 w/Sony.
CruizinDux is online now   Reply With Quote
Old 08-04-2016, 09:10 AM   #8
Rich and Kat
AIRHEDS's Avatar
Virginia near , Washington, D.C.
I believe the OP's original question has been answered, so I'd like to ask if anyone can share what happens when a factory solar system is added to the configuration?
Does the factory solar charge the batteries in both the use/store positions? Or does the switch need to stay in the "use" position at all times? Also, is the solar charger at all a concern, like the standard factory charge controller when connected to shore power?
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 08-04-2016, 11:30 AM   #9
Can't answer for factory solar. Our kit from AMSolar is connected direct to batteries, it charges no matter what use/store is set to.
Old 08-04-2016, 12:01 PM   #10
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi Rich, the factory solar charges whether the switch is set to use or store, and there is no concern specifically with the solar controller if you stay plugged into shore power. Joe
jayseejay is offline   Reply With Quote
Old 08-05-2016, 05:19 AM   #11
Rich and Kat
AIRHEDS's Avatar
Thank you Joe!
Rich
KB2ZMF
Save
Best way to use solar w/ shore power dquirk29 Electrical - Systems, Generators, Batteries & Solar 19 01-18-2016 11:19 AM
Using a 30A cord with a 50A shore power terminal thebreezeman Electrical - Systems, Generators, Batteries & Solar 46 02-08-2015 07:12 PM
Store/use switch and charging B25guy Electrical - Systems, Generators, Batteries & Solar 21 07-05-2010 02:52 PM
Using shore power w/o batteries 1989 Excella 1000 VABelson Batteries, Univolts, Converters & Inverters 4 12-29-2007 09:58 PM
"Store-Use" SWitch Rleirer 2003 Safari 10 04-17-2003 02:07 PM
