Old 10-07-2014, 05:59 PM   #1
2014 23' Flying Cloud
North Bend , Washington
Use/Storage switch problem
Purchased my 25' Flying Cloud in March, 2014. Everything runs great with one exception. At my storage site, I have recently discovered that my use/storage switch won't engage. Dead, and nothing turns on. So I connected to the truck, ran it for a minute, and then the switch came on, AND the battery is totally full. This problem has repeated over and over again for the past two months. If the trailer sits for a few days, the use/storage switch seems to disengage from its power source. Any idea what's happening?
CommoTyee is offline   Reply With Quote
Old 10-07-2014, 06:28 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Off the cuff it sounds like the battery is discharging to much to activate the relay. Do you hear it click?
Doug and Cheryl
Old 10-07-2014, 09:30 PM   #3
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
How have you confirmed batteries are full?
Have you assured the battery terminal connections are good?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 10-07-2014, 09:36 PM   #4
Is does not click. Dead when trying to activate the switch. Batteries are fully charged, and topped off with water. Have double checked all terminals. Any further thoughts?
Old 10-07-2014, 09:48 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Loose wire at the switch? Vibration from truck motor causing it to touch and work?
Once on, will it stay on after you disconnect the tow vehicle?
Foiled Again is online now   Reply With Quote
Old 10-07-2014, 09:58 PM   #6
Spamcan's Avatar
2015 30' FB FC Bunk
Portland , Oregon
I had the same problem with my 2013 25' International on my first outing with the new trailer. Turns out the switch itself was bad, and it was replaced under warranty.
Spamcan is offline   Reply With Quote
Old 10-07-2014, 10:16 PM   #7
dkottum's Avatar
A couple of things are wired around the battery disconnect and unaffected by it. An easy one is the tongue jack. Can you raise and lower it when the switch is not working. That will confirm the batteries are strong enough to operate the relay, better than a voltage check.
The battery disconnect relay is usually on the lower forward left side, under the seat if you have a front dinette. There should be an access door under the seat cushion, the relay is inside with two large wires and two smaller wires. Check the small wires for voltage. If none there remove the battery switch panel and check for voltage there. The problem is most likely a loose connection somewhere or bad switch, maybe further back. The batteries must actually be strong enough to actuate the relay.
Doug and Cheryl
Old 10-08-2014, 08:50 AM   #8
Yes, it does stay on after I disconnect the tow vehicle.
Old 10-08-2014, 09:59 AM   #9
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
My switch failed, it would only turn off. You could hear the solenoid popping on the off side. The switch felt broken internally on the on side.
My guess the connections from the batteries to the solenoid are suspect, also there are fuses on both, on/off sides of the solenoid.
Loose nuts are usually the cause for intermittent electrical issues.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 10-08-2014, 11:07 AM   #10
1974 Argosy 20
Kooskia , Idaho
I would say it is a warrantee issue. Have your dealer make it right. You have a 2 year warrantee on the entire rig.
Old 10-08-2014, 11:29 AM   #11
dkottum's Avatar
It's a warranty issue but if something simple like a loose connection it's easier to tighten it down than to take it to the dealer, wait a week or so, and go back and get it only to be told everything checks out.
Doug and Cheryl
whats this switch? next to storage kill switch. Looking4air Electrical - Systems, Generators, Batteries & Solar 1 06-28-2013 01:59 PM
Store/use switch and charging B25guy Electrical - Systems, Generators, Batteries & Solar 21 07-05-2010 02:52 PM
Light Switch (Wall Switch) for 69 Overlander mbmbstreamer Lights - Interior & Exterior 3 03-21-2010 04:39 PM
Battery Isolation Switch Use? Wingeezer Batteries, Univolts, Converters & Inverters 14 08-28-2009 10:28 AM
"Store-Use" SWitch Rleirer 2003 Safari 10 04-17-2003 02:07 PM
