Old 12-09-2018, 11:39 AM   #1
2018 25' Flying Cloud
Smyrna , Georgia
USB to female cigarette lighter adapter
I have 2018 Flying Cloud. We use cpap machines that will run on 12v when boo docking. Has anyone seen or used an adapter to operate the cpap from the USB port?
DKGA is offline   Reply With Quote
Old 12-09-2018, 11:51 AM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
So, there's this:
https://www.amazon.com/ARECORD-Cigar.../dp/B01J67JIOQ
But it's 0.8 amps max. I don't know how much your CPAP draws, but I expect it's probably more than that.
Likely, a better solution would be to tap into the 12V wire supplying the USB outlet and add a 12V cigarette lighter style outlet of your own. That way, you're not stepping down to a 5V 2A USB and then back up to 12V 0.8A.
TheGreatleys is offline   Reply With Quote
Old 12-09-2018, 11:54 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I use CPAP and 400 watt modified Sine wave inverter plugged into the cigarette lighter. works fine. I use heated hose and humidifier.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-09-2018, 12:19 PM   #4
1974 27' Overlander
This thread might be an instructive read.
http://www.airforums.com/forums/f542/what-was-airstream-thinking-no-12v-outlets-179323.html
Old 12-10-2018, 10:25 AM   #5
2017 27' Flying Cloud
Brookfield , New Hampshire
I'm on the road and can't find the exact thread here on Airforums but there is one that shows a receptacle from amazon similar to if not the same as this
https://amzn.to/2L81VzL
Check the specs to make sure this one will work. I replaced both USBs in our bedroom to this type of receptacle and run the CPAPs off of them without any problems. No need to run the inverter any more at night.
Larry
devilsbox is offline   Reply With Quote
Old 12-10-2018, 10:56 AM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I run my CPAP in the Airstream by plugging into one of the inverter outlets. My CPAP requires 24v DC so it's either using a brick to downconvert 120V AC or a different one to upconvert 12V DC, and my trailer came with the inverter and the ResMed upconverter is $80-$100. So far the inverter is doing fine.
David
Old 12-10-2018, 12:43 PM   #7
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
USB is 5v, most CPAPs are 12-24v, so no, you can't use any kind of adapter.
Old 12-10-2018, 01:19 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
You can't even reliably charge 2 high-demand USB devices on one of the OEM ports in the Airstream. I now have a nice BlueSea port by my bed because the generic OEM one slagged while charging my phone and iPad at the same time. The very hottest USB standard is 5v/3A (15W) so all you'd be able to do at 12v would be 1.25A (that same 15W) *IF* you had a perfectly-efficient converter.
David
A Lighter Mod - Cigarette Lighter, that is Alex AVI Sprinter and B-van Forum 18 12-09-2018 01:09 PM
Installing a 12 volt Cigarette Lighter Style Adapter on 2017 International interstateflyer Electrical - Systems, Generators, Batteries & Solar 22 05-29-2018 12:54 PM
'67 Caravel cigarette lighter deccli Batteries, Univolts, Converters & Inverters 15 11-12-2014 09:41 PM
Cigarette lighter inverter for Samsung TV? rasjad Audio, Video & TV 4 06-29-2014 09:48 AM
Lights quit working after plugging cell phone charger into cigarette lighter hagnik Lights - Interior & Exterior 6 06-20-2011 10:57 AM
