Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-23-2017, 12:32 PM   #21
2015 30' FB FC Bunk
Ayer , Massachusetts
I just replaced my ports with Blue Sea units and they work great. Got them on Amazon.
If you read carefully, they manufacture to a non-spec which seems to make a difference.
Ted S. is offline   Reply With Quote
Old 04-23-2017, 02:41 PM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I find those adapters all die pretty quickly. I just put in cigarette lighter sockets and plug an adapter into that. I keep spares on hand and can just pop a new one in when needed.
2019 Ford Expedition Platinum
Old 04-23-2017, 03:13 PM   #23
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
It is important to connect the + and - leads correctly on the USB port otherwise it won't work.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 11-20-2017, 04:08 PM   #24
chaseav's Avatar
2015 25' FB International
Originally Posted by WkendWarrior View Post
The port itself. No idea of make or model.
It’s pronounced Chy-nuh.
chaseav is offline   Reply With Quote
Old 11-20-2017, 04:26 PM   #25
Zionsville , Indiana
USB Charging Ports not charging
As Adventure AS points out, polarity may be important.
Notice on the original port one tab is copper, the other silver. That typically indicates polarity. Positive goes to the copper tab.
If you reversed the polarity during reassembly the port most likely wouldn’t function.
The new port has two silver tabs which typically indicates polarity is not important and it will work even if the inputs are reversed. (Or they rely on some marking on the device to indicate polarity).
Did you check the polarity of your connections on the original?
DRPREECE is offline   Reply With Quote
Old 11-21-2017, 02:25 AM   #26
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
The OEM units can, in theory, provide 5V at 1.0 amp. Many of the newer devices (like an iPad) want 2.0 or even 2.1 amps to charge and can possibly overload these lowest possible cost units that Airstream installs.
Old 11-22-2017, 08:01 AM   #27
2022 27' Globetrotter
Bay Area , California
This thread lives! Good call on the polarity, its possible that was the issue on my original port - didn’t realize that at the time (this was about 2 years ago). I probably reversed the connectors to check, but honestly don’t remember. Actually thinking about it more, I don’t think i disconnected the USB port as part of the original work. So the wires shouldn’t have been reversed...
Anyway, as it turns out, one of the 2 USB ports in the bed area went out recently, and last week I replaced both ports with the Blue Sea units I mentioned earlier in the thread. First one i reversed the polarity and as you point out, it didn’t work. Good news is the Blue Sea units have that little green light to show you right away that you’ve made a mistake. ;-)
My conclusion - the OEM USB ports were, uh, not the highest quality...
WkendWarrior is offline   Reply With Quote
Old 12-15-2017, 08:43 PM   #28
chaseav's Avatar
I just swapped out my factory USB port (which had power but would not actually charge) with a new Blue Sea Systems unit. Total install time was 5 mins, the last two mins of which were spent figuring out if "that was it...?" Downside though, it has a little green light on it to let you know it's on. That's going to have a power drain (?) and may be annoying at night.
Thank you to whomever it was that suggested replacing with this unit and suggesting how simple it was.
Old 12-16-2017, 06:32 AM   #29
Interesting thread. Thanks for the thorough detail.
StrmyWeather is offline   Reply With Quote
Old 09-08-2018, 08:12 PM   #30
TinVenture's Avatar
2016 19' International
Orange County , California
Thanks for the detailed description. One of my USB ports have been working intermittently. I’ll have to take a multimeter to it and maybe time to order a Blue Sea as well.
Jon
www.TinVenture.com
Instagram: TinVenture
TinVenture is offline   Reply With Quote
Where is the AC recharge ports for dash? 92landyacht Mechanics Corner - Engines, Transmission & More... 29 08-27-2015 04:47 PM
USB charging port jennian Sprinter and B-van Forum 7 04-04-2015 04:18 PM
120 Volt outlets w/USB ports PA BAMBI II Electrical - Systems, Generators, Batteries & Solar 3 06-30-2014 05:52 AM
Audio ports HDMI cords jkinglet Sprinter and B-van Forum 7 05-22-2014 08:10 AM
What US ports ship trailers to UK Edinburgh Shipping & Export/Import 15 09-21-2012 03:07 AM
