Old 04-18-2016, 01:19 PM   #1
JJ1
2009 23' International
Redondo Beach , California
Upgrading to 6V T-105's
I am upgrading the batteries on my '09 23D' International. I know that my batt box has to be modified to accommodate the taller T-105's. Are there any other upgrades I should expect? I am going to add solar down the line, just it right now.
Thanks for the hell and advice!
John
JJ1 is offline   Reply With Quote
Old 04-18-2016, 01:40 PM   #2
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
We upgraded our 2008 23' L-lounge to 6V batteries and appreciate the extra capacity. We upgraded the converter at the same time (and installed 200w of solar). With expensive new batteries going in this might be a good time to upgrade your converter and/or inverter for the longer term.
field & stream is offline   Reply With Quote
Old 04-18-2016, 01:52 PM   #3
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Thinking about doing the same thing. Do any of the wires need to be extended/altered?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 04-18-2016, 02:03 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I upgraded my converter and added two inches to the top of the box. Photo shows the extension and plug for portable solar .
MICHAEL
Old 04-18-2016, 02:03 PM   #5
Tincampers's Avatar
Sneedville , Tennessee
I had to pull in some extra slack for my inverter cables, but the battery cables were fine.
Tincampers is offline   Reply With Quote
Old 04-18-2016, 02:13 PM   #6
grizbear's Avatar
2004 25' Safari
Crestview , Florida
6 volt conversion
I did the conversion last year its been great put in the PD 4655 3 stage converter/charger at the same time. The wires are pretty simple pos. camper wire to batt 1 pos post, neg of battery 1 to pos post of battery 2 and neg camper wire to neg post of battery 2. The tongue jack wire to pos post battery 1. You will have one less jumper wire between the two batteries than 12volt setup. Good camping.
grizbear is offline   Reply With Quote
Old 04-18-2016, 02:40 PM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Portable solar details?
Was think of doing something similar (portable panels that can be easily disconnected). What equipment did you use?
BambiTex is offline   Reply With Quote
Old 04-19-2016, 06:44 AM   #8
AWCHIEF's Avatar
Images: 33
Renogy 100 watt suitcase. Bought directly thru Renogy. They give a substantial military discount and free shipping. Recently used it for several days dry camping in Key West. With frugal battery use on Sunny days it worked very well, easily getting my batteries back up to 100%. Cloudy no sun days not so good of course. I have a higher rated 30amp controller and an additional 85watt panel that I am going to add to the system. My next major purchase is going to be a small generator for those all too common overcast days.
MICHAEL
Old 04-19-2016, 07:11 AM   #9
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Is the disconnectible plug part of the package?
Old 04-19-2016, 07:56 AM   #10
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Upgrade your battery cables while you are at it to a thicker gauge.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-19-2016, 10:31 AM   #11
JJ1
Thanks for the advice!
Old 04-19-2016, 11:59 AM   #12
AWCHIEF's Avatar
Images: 33
Nope, it is a SAE water proof two wire plug used commonly on boats. I bought the base thru Amazon packaged by Zamp. I have a bag full of the other connectors left over from my boating days. I use them for all removable DC connections.
MICHAEL
Old 04-19-2016, 12:05 PM   #13
2014 27' FB International
Clearwater , Florida
For my Renology suitcase solar set up I bought "Anderson" 50amp connectors and 10 gauge landscaping wire from Amazon. Soldered all connections. These connectors are male-female and as long as you are careful about positive negative on assembly the connections are idiot proof.
ChuckFeldt is offline   Reply With Quote
Old 04-21-2016, 08:45 AM   #14
2010 19' International
Evergreen , Colorado
AWCHIEF, that extension on your battery box looks sweet. Can you provide details on construction materials and methods? I am planning on modifying my box to accommodate the T-105s as well.
Thanks.
alanbryant is offline   Reply With Quote
Houston area I10 or 105 slabatFB25 On The Road... 9 09-09-2015 08:32 PM
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
Upgrading my CCD to dual batteries silverback Electrical - Systems, Generators, Batteries & Solar 7 05-20-2008 07:58 AM
I'm upgrading my tow vehichle JWest Our Community 19 04-27-2003 09:04 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
