Old 04-22-2016, 07:31 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Used 2 inch aluminum C-channel. Cut to almost fit (not much of a metal worker) and attached with self tapping screws to box. If I did it again I would use light weight steel C-channel or farm the job out to a shop and have the frame aluminum cut, welded and attached properly. I can weld light steel but not aluminum. That is an art form and is worth paying someone to do it right.
MICHAEL
Old 04-22-2016, 09:25 AM   #16
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Lewster (Lew) recommended this to me awhile ago, and I believe he does this on his upgrades.
Consider installing a 50 amp circuit breaker between your batteries and the Airstream. I installed a 50 amp surface mountBlue Sea Systems 285-Series Circuit Breaker this should protect the Airstream's 12v systems from any power spikes.
Hopefully, my diagram will not confuse you. Ignore most of it. You can see where mine is, coming off my batteries main power and before it connects to the Airstream's main bus.
And here is a photo of it before it goes to the Airstream distribution bus.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-23-2016, 06:28 PM   #17
2005 28' Safari S/O
Ocean Springs , Mississippi
6 volt added
I constructed a new "raised top" for my battery box to add 3 1/2 inches so the T-105 6 volt batteries would fit inside. I used an old stop sign or two and alot of rivets for the project.
I use the outdoor electric outlet mounted to the frame as an input for my Go Power 80 Watt solar cell (or as a direct input to charge with my Honda 1000). I use standard 3 prong connectors on my solar and generator cables as inputs.
george1 is offline   Reply With Quote
Old 04-23-2016, 07:17 PM   #18
AWCHIEF's Avatar
Images: 33
George, nice looking box. I like having the extra room above the batteries.
MICHAEL
Old 05-02-2016, 02:49 PM   #19
2005 22' International CCD
Cambria , California
Better Trojan T105s
I've used Trojan 6v deep cycle flooded batteries for years. I just had to replace my batteries and found that Trojan has "Smart Carbon" technology in their new "RE" line of batteries.
Deep-cycle batteries used in off-grid and unstable grid applications are heavily cycled at partial state of charge (PSOC). Operating at PSOC on a regular basis
can quickly diminish the overall life of a battery, which results in frequent and costly battery replacements.
To address the impact of PSOC on deep-cycle batteries in renewable energy (RE), inverter backup and telecom applications, Trojan Battery has now included "Smart Carbon™ as a standard feature in its Industrial and Premium flooded battery lines.
The RE line has double that warranty and are designed to last 10 years. They cost about 10% more but will more than pay that back with longer life.
Ziggy2 is offline   Reply With Quote
Old 05-02-2016, 02:51 PM   #20
One note on the new T105 RE batteries. The terminal at the top is larger than your standard car type so some of your modified battery boxes could encounter a problem. Mine just barely fit.
Houston area I10 or 105 slabatFB25 On The Road... 9 09-09-2015 08:32 PM
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
Upgrading my CCD to dual batteries silverback Electrical - Systems, Generators, Batteries & Solar 7 05-20-2008 07:58 AM
I'm upgrading my tow vehichle JWest Our Community 19 04-27-2003 09:04 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
