Old 05-19-2017, 11:26 AM   #1
Fulltimer
1989 34' Limited
Greenville , South Carolina
Upgrading My Airstream from 30amp to 50amp
Looking for someone in the southeast who could handle upgrading my 1989 34' limited from 30amp to 50amp and install a new rear AC?
BenMoffett is offline   Reply With Quote
Old 05-19-2017, 11:30 AM   #2
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
Out of Doors Mart, Colfax, NC
Airstreamin' dreamin'.
Follow our blog! http://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 05-19-2017, 11:57 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Since to second AC will likely drain directly to the roof you are only dealing with electrical issue and any electrician can handle that. Pulling the umbilical through the body is going to be a challenge. You might consider installing a new panel, close to the entrance under the bed, for the 50 amp service and feeding the old panel and the new AC from it
Unless you are willing to remove the ceiling panel surface wiring may be the only option to feed the new AC.
Look very seriously at the air distribution configuration inside the new AC you select. The one I installed as a replacement on my trailer deliver NO AIR forward because of the location of the electrical box above the ceiling shroud. A very stupid design.
2004 Excursion 4x4
Old 05-19-2017, 12:12 PM   #4
Central , Mississippi
I added a 2nd ac to our '91 34'. I used a 2nd breaker panel installed in the street side bedside cabinet and a separate 20 amp inlet. No need to upgrade to 50 amp unless you just want too. I routed the AC drain forward thru the ceiling into the bathroom, down the vent cover, behind the toilet and out thru the floor. Somewhere here on the forums I posted photos. Look for 'miles and miles of aluminum' under the 1000 Excella threads.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 05-19-2017, 02:31 PM   #5
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
I just completed the conversion you are looking at and like the way we did it. We separated the line from the box fed by the generator that feeds the rear AC unit and wired a heavy gauge SO cord to feed the rear unit. We then ran a separate SO cord
from the generator output for that circuit and let them both hang into the generator compartment (using insulating grommets). We put a 20 amp female connector on the generator output line and a 20 amp male on the line feeding the rear AC. We can now feed the rear AC unit from a shore cord or the generator and can't get things hooked up wrong. No switches or relays and it is idiot proof.
John Woodrow is offline   Reply With Quote
Old 05-19-2017, 02:48 PM   #6
Long Island , New York
FYI: http://www.airforums.com/forums/f205...num-54749.html
Old 05-19-2017, 03:54 PM   #7
Originally Posted by OTRA15 View Post
Well there it is!
Thanks, I'm no good at linking stuff on an iPhone
Old 05-20-2017, 02:08 PM   #8
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
install 50 amp box under bed or where can access ( your 30 amp box is in d/s/r overhead ? ) pull 30 amp shore cord back into trlr , cut plug off and feed into 50 amp box . hook to 30 amp brkr in 50 box .
run new 12/2 circuit to microwave , run new 12/2 circuit to ac mode on water heater ,
from 50 amp box leave ac outlets ( factory alone and install new 1s at micro and wtr htr ) fish new circuit from rear vent to 50 amp box ( fun part ) install 50 amp power port on exterior wall and go buy cord . this way all services are available at same time .
we normally also add 2 x 1400 watt forced air baseboard heaters to the ac circuits as not used at same time so will handle easily . replace range with 2 burner elect stovetop . send private contact if you need better description . we have removed propane tanks from 3 in the last 5 years and use space for charcoal and grill :-)
crestonrv is offline   Reply With Quote
Old 05-20-2017, 09:26 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
our 1999..34'...
Installed AC deux (power and condensate line)..and , upgraded to 50 AMP..
ID:	285962   Click image for larger version
ID:	285964   Click image for larger version
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-20-2017, 09:58 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here are a couple other pics
ID:	285966   Click image for larger version
Channing
WBCCI# 30676
Old 11-12-2017, 09:53 PM   #11
Mt Pleasant , South Carolina
I would like more info. I see a few sacrificial varistors and serviceable boards. What am I looking at exactly.
Jigs is offline   Reply With Quote
Airstream Classic 31 with twin bed option and 50amp dual AC coolbikeman Airstream Classifieds 0 02-04-2017 09:36 AM
Using a 30amp cord on a 50amp connection Pat Cassity Electrical - Systems, Generators, Batteries & Solar 28 11-05-2015 08:05 PM
Can a 30AMP 240v provide 2 30AMP 120v?? VeggieBullet Electrical - Systems, Generators, Batteries & Solar 17 05-29-2013 09:28 PM
50amp for 30amp trailer? racoco Electrical - Systems, Generators, Batteries & Solar 15 08-24-2007 07:43 PM
30amp to 50amp? alfalsetto Airstream Motorhome Forums 17 08-16-2003 06:42 AM
