Old 05-03-2016, 01:52 PM   #1
2008 19' Safari
Toronto , Ontario
Upgrading '08 Dometic thermostat
Is it possible to upgrade the older type thermostat to one of the newer more functional ones? I have a new to me '08 Safari SE.
Thanks in advance for any advice/
oscarb57 is offline   Reply With Quote
Old 05-03-2016, 02:33 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
A thermostat only has one function. Turn on and turn off the heater. If it works that is the best you can do.
I say if it works because I did have to do some modifications to the spring to get the hysteresis more in line with the capacity of the heater.
2004 Excursion 4x4
Old 05-03-2016, 02:51 PM   #3
2008 19' Safari
Toronto , Ontario
Thanks, HowieE
By "thermostat", I was referring to the controller on the wall that controls the air conditioning, heat pump fan and heater components together. The newer digital-type units appear more functional than the relatively primitive one in my 19' Safari. I know they all do the same thing but I find the older model that I have is not only difficult to see but is also not inspiring nor in keeping with the otherwise neat look and potential of the newer one I have seen.
Old 05-03-2016, 03:18 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Good question. I would like to change my Dometic controller to the newer style but since we have an earlier version of the Penquin AC/heat pump I bet its not swappable. I believe the 5 button thermostat is analog and the Comfort Control Center for the Penquin II are digital. I've see some circuit boards available to allow a Penguin II to use the older 5 button thermostat but I can't find any info for using the newer thermostat models on the Penguin I AC/heatpump.
If your older thermostat is broken you can still get them.
Kelvin
Upgrading to a Digital Thermostat.. Need some help! Keyair Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-16-2016 09:52 AM
Dometic thermostat Tino643 Electrical - Systems, Generators, Batteries & Solar 4 05-25-2013 09:42 PM
Dometic Briskair thermostat not working on heat perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-23-2012 07:07 PM
Dometic CCC 2 Thermostat (12 button style) Terratravels 2009-2015 Flying Cloud 12 10-22-2012 06:53 AM
Dometic RM100 electric thermostat problem blickcd Refrigerators 0 08-31-2009 10:32 AM
