Old 10-24-2006, 08:54 PM   #1
GoNomad's Avatar
1975 Argosy 28
Anderson , South Carolina
Upgrade to a new system monitor?
Had the trailer at a rally this past weekend and couldn't help but notice how nice the 2005 system monitor is. As much as I love my vintage AS I am considering changing my 1972 system monitor for a new one. Currently I have a power on light that is inop, an Am meter that is inop, a battery condition gauge that kind of works, the potable water monitor works, the black tank kind of works, and the water pump switch works. I understand that from an aesthetics point of view this is not recommended but since I have a new converter (Intelli power) am planning on switching to an AGM battery, and neither the clock nor the temp gauge work. I am working on updating the whole panel.
So the Questions is do I need to rewire each system and can I use the old sensors with the new monitor?
Nick & Holly
1975 Argosy 28 Rear Bath 1963 Shasta Airflyte
2008 Toyota Tundra Double Cab SR5 5.3L 4x4
"We've got PBS minds in a MTV world" J.B.
GoNomad is offline   Reply With Quote
Old 10-25-2006, 10:57 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
RV tank monitor
Do a google search "RV Tank Monitor" lots of hits, I like this one www.snake-river.org. There is another company called Garnet Technologies that has a sensor that can be cut down to 5" but they are quite abit more expensive then the one from Snake-river.
Old 10-25-2006, 11:13 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The system uses a completely different type of sensor so you would have to replace them also. I'm not sure where those things are located.
Here is a link to the manufacturer's site. http://www.catconproducts.com/
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-25-2006, 11:20 AM   #4
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Jack
I have a pretty good idea where the black tank sensor is located
Fyrzowt is offline   Reply With Quote
Old 10-25-2006, 12:59 PM   #5
Aerowood's Avatar
Arvada , Colorado
The Snake River system uses self adhesive sensors mounted on the outside of the tank, just as long as you can get to one side of the tank for its full height. Exisisting wiring genarally can be used and the tanks must be of plastic, fiberglass, or composite construction. I most likly will use the Snake-River unit when I get to that point of my rebuild, and plan on wiring it for this installation in the near future.
Old 10-25-2006, 01:32 PM   #6
bedfords's Avatar
1975 29' Ambassador
Littleton , Colorado
I quickly looked through the Snake River website. It doesn't appear they have the capability to monitor the battery. How are you guys handling that or did I just miss it somewhere?
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 10-25-2006, 03:25 PM   #7
Aerowood's Avatar
Arvada , Colorado
I'll most likly just wire in a seperate voltage indicator and pump switch. I like to have voltage continiously monitered so I can just glance at it.
www.rvgauge.com carry SeeLevel systems and their units have a voltage monitor.
Old 10-27-2006, 07:02 AM   #8
GoNomad's Avatar
1975 Argosy 28
Thanks for the great information
This has been a great help, Aerowood as you get further along with your upgrade please post a few pics here so we can see how it turns out.
I have a freind who restores boats and he is trying to work up a system monitor system using marine grade components, I will post his findings when he gets them to me.
Has anyone tried to price the system AS is currently using on the new models?
Nick & Holly
Important upgrade - Cap Puller Janet H Exterior Restoration Forum 9 04-18-2004 05:45 AM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Battery Monitor Les Gilliam Electrical - Systems, Generators, Batteries & Solar 11 10-07-2002 08:13 AM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 03:35 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
