Old 09-30-2006, 09:11 PM   #1
1975 31' Sovereign
Gainesville , Florida
Univolt System for charging
I have a 1975 Sovereign (31 ft.). Inside I have a complete working recording studio for remote jobs on the road and, and for mixing at home. The Univolt System for charging-stock Airstream- is making a noisey hum. When I'm working, I use only city electrical service,(120 V). How can I disable the charging system? I've tried and failed. Please help,
Justin. email:me4trzn@yahoo.com
rozwd is offline   Reply With Quote
Old 09-30-2006, 09:18 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The PO of my 75 showed me a trick he used to kill the converter so he could sleep at night. At the circut breaker pannel I have 4 CB's. One main in and 3 for 100 AC circuts. Tripping the right CB (one of te three) will remove power to the univolt. One note, on my Trade Wind killing that CB will also remove power from the outside patio outlet.
Richard
Old 09-30-2006, 09:54 PM   #3
1975 31' Sovereign
By flipping either of the 2 circut breakers-not Main and not AC- I found that one controls the Forward Cabin, and one controls the Aft (rear). I need them both. rozwd
Old 09-30-2006, 10:01 PM   #4
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
Hi rozwd.
Unplug it. On my '75 it plug in under the sink. Hard to get to though. On my '82 there is a light switch that had been installed. If you Univolt is not under the sink find the hum and an outlet should be near by. Unplug.
GO Bob is offline   Reply With Quote
Old 09-30-2006, 10:13 PM   #5
1975 31' Sovereign
Hey GO Bob, "We're goin' in." It is under the sink but I only got as far as the DC fuse panel down there.
rozwd
Old 10-01-2006, 05:09 AM   #6
Waynon's Avatar
1986 34' Excella
Converter Hum
Does the newer type replacement converter that I often read about here on the forum have the hum? It's a pain late at night!
Waynon
Waynon is offline   Reply With Quote
Old 10-01-2006, 06:47 AM   #7
1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Hum-free converters
I put in an Intelipower 60 with Charge Wizard this year. The installation was easy, the performance is outstanding, and the hum is GONE. Deposit the Univolt in the dumpster.
26.982 amu is offline   Reply With Quote
Old 10-02-2006, 08:07 PM   #8
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
I said hard to get to. The fuse area would be to easy.
Go up to the shelf, go all the way to the wall. It is a 90 degree plug so it is not sticking out. Tie a rope to it first. This will save diging blindly behind the shelf. I did find a small pan the PO had lost. There is not much room to pull and I see why the light switch was installed of my 82.
Good luck.
Old 10-02-2006, 08:33 PM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The PO of our 71 had a surface mounted switch installed in the bunk over the Univolt - so it sticks out on the wall and actually replaces the bracket at that end that supported the drape railing. All it does is shut off the outlet that the Univolt is plugged into - everything else is still powered.
Old 10-02-2006, 08:50 PM   #10
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Wall switch for Univolt
IIRC that switch was installed and retrofitted to some trailers to turn off the Univolt so as to quiet the trailer for sleeping. By turning it off you don't convert A/C to D/C power and you also don't charge the battey. You must turn the switch back on to run D/C powered items and to charge the battery from shore power. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 11:08 PM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 04:35 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 08:39 PM
