Old 04-29-2014, 08:23 PM   #1
1966 17' Caravel
Klamath Falls , Oregon
Univolt system
We have a 66 Caravel and my question to you is that if you run your battery down, is there a point to where it affects the two circuit transformer in a fashion that will not allow the "city power" mode not to work?
Stefandmissy is offline   Reply With Quote
Old 04-29-2014, 08:49 PM   #2
Ottawa , ON
Originally Posted by Stefandmissy View Post
We have a '66 Caravel and my question to you is that if you run your battery down, is there a point to where it affects the two circuit transformer in a fashion that will not allow the "city power" mode not to work?
I -think- I understand you, and my guess is no. When we bought our '74 Sov, it had NO battery, and we ran the usual things (furnace, lights, water pump, WH etc) just fine for over a year.
We then replaced the Univolt, and the results were the same (minus the Univolt hum) for another year with no battery.
What do you mean by "the two circuit transformer", by the way?
Old 04-29-2014, 09:56 PM   #3
1966 17' Caravel
Two circuit transformer
I am refering to the box that has two togel switches that go from city power to trailer battery power.
Old 04-29-2014, 10:42 PM   #4
1966 17' Caravel
Oh, By the way, I'm a two rivit Member but you are a Moderater. What is a moderater?
Old 04-29-2014, 11:46 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
What's a Moderator?
We (the moderators) are a group of volunteers who help to run these forums by assisting other members with technical issues on the forums, watching for spammers and scammers on the forums and the classifieds and dealing with disputes and violations of our Community Rules. Other than that we're Airstreamers one and all.
— David
Old 04-30-2014, 01:01 AM   #6
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Hey Stefandmissy the answer is no but the univolt in ours no longer worked anyway so as we go along we are replacing it. Check the input circuit breaker comming into the caravel (ours was in the curbside closet) and the shore power breaker to insure that you have power. The shore power battery power switch determines weather you 12 volt power is comming from the transformer or the battery. I am assuming that the univolt is plugged in and the fuse is good. The AC is feed into the breaker box from the shore power outlet and distributed to the trailer through breakers that are in that box in the closet. Hope that this helps.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
Bad univolt system GAT Batteries, Univolts, Converters & Inverters 3 08-30-2010 10:20 AM
Univolt or 12v System Gone Wrong AustinAir Batteries, Univolts, Converters & Inverters 4 04-09-2009 11:10 PM
69 Safari Univolt system Protosport Batteries, Univolts, Converters & Inverters 2 05-28-2008 03:02 PM
Univolt System for charging rozwd Electrical - Systems, Generators, Batteries & Solar 9 10-02-2006 07:50 PM
