Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-23-2004, 06:59 AM   #1
Profile:
Univolt. Still can't solve 12 volt lighting!
Hi Guys,
I hope that someone on this list can help me. I have a 1976 Argosy 28 footer, remarkably original condition with very little after market modifications. The engine battery system works fine. The Univolt hums when plugged in, and appears to be putting out around 12 to 16 volts DC for charging.
The sytem is set up so that the interior lights are supposed to run off of the coach battery in normal mode, or will run off of the engine battery when the key is turned to the accessory position. This would also allow the Univolt to recharge the engine battery (as well as the coach battery) when the key is in the accessory position.
When plugged into a city 110 outlet, all of the interior 110 outlets work fine, and the univolt appears to put out proper charging voltage, but none of the 12 volt lights will work off of the coach battery. They will work off of the engine battery when the key is turned to the accessory position.
There appears to be 12.9 to 13.5 volts at the coach battery terminals indicating that the Univolt is producing the voltage to charge the battery, and this voltage drops (or disappears if the terminals are not on the battery) when the Univolt is unplugged, so I do feel as though the Univolt is operating properly.
But the coach battery appears to be disconnected from the entire lighting system, or the lighting system appears to be disconnected from the Univolt and from the coach battery, as no 12 Volt lights or accessories will work without thekey in the accessory position, which brings the engine batteyr online.
I have checked the coach battery polarity, and although correct, there is a small weird curiosity. A volt meter from the NEGATIVE terminal of the coach battery to a vehicle ground reads 12 Volts. Obviously, the Negative terminal should have continuity with the ground, and not produce 12 Volts. I learned of this factor when I accidentally touched the NEGATIVE battery post to the vehicle ground and got some sparks! I would have expected this with the POSITIVE terminal, but not the NEGATIVE terminal.
So could the battery have switched polarity, somehow. Or could the interior lights be disconnected from the Univolt system or coach battery? Any other ideas?
I have solved almost all of the other problems, but this one has me completely stumped!
Also, can the air-conditioner be recharged, now that freon has been taken off of the market. Should I look for a trenchcoated gray market freon dealer in the back alleys?
Finally, what is the deal with the 454 exhaust manifold gaskets. Is there a permanant fix. Do you recommend installing TWO gaskets, or planeing the heads before resinstallation?
Thanks for all of your help.
Chas
Please check out our MICROCAR website at:
www.bubbledrome.com
Thank you
chasgould is offline   Reply With Quote
Old 04-23-2004, 07:14 AM   #2
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Just a couple of answers
The Freon is still available, expensive and only liscensed tech can purchase.
If you live close Mexico, you can buy it there. Or grey trench coat dealer is in order, still expensive.
The manifolds, Nope, no fix other than aftermarket manifolds or headers that do not crack or warp. Yes you machine manifolds and install new gaskets if the manifolds are not damaged. You can also add deflectors to force more air onto manifolds, this is a GM retrofit but you can do it yourself. You can add hoses to direct air onto your manifolds.
As for electrical problems, I am not familiar with the older models.
Smily
smily is offline   Reply With Quote
Old 04-23-2004, 07:43 AM   #3
Profile:  LOST , Hawaii
Are they leaking now? If so do as Smily says if your mating surfaces are bad. 2 gaskets will be counter productive, more insulation and what you really want is the heads and manifolds to be fairly equal in temperature. Use new locking fasteners, torque and retorque after a few heat cool cycles. Let your engine run at idle for 3-5 minutes before shutting it down, especially if it has been running hard. A lot of heat builds up after shut down, this is when problems start.
John
74Argosy24MH is offline   Reply With Quote
Old 04-23-2004, 07:46 AM   #4
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
You have a bad ground from the coach batteries to the coach body, or a blown negative fuse to the Univolt. Repair as necessary. R134a conversion costs about the same as a charge of R-12, with the benefit that in the future you can buy refills from the parts store, and do it yourself.
(No Longer at Inland RV)
Old 04-23-2004, 08:25 AM   #5
Profile:
Univolt problems
Thanks to John, Smiley and everyone else for your help. You guys are great.
Hey John, the large Negative fuse in the front of the engine compartment, behind the service door, seems to be fine, as does the Positive fuse, and all of the fuses at the Univolt.
Should I just run a new test lead from the negative coach battery to a coach ground somewhere, just to test and see if that cures anything?
I am in Massachsuetts. Does anyone know where I can go to convert the freon to the new coolant, and roughly how much it will cost.
Thanks again for all of the help.
Chas
www.bubbledrome.com
Thank you
Old 04-23-2004, 08:50 AM   #6
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Where in MA are you?
I bet Marty's USRV (the local airstream dealer) could take care of you.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-23-2004, 08:52 AM   #7
Profile:
I am in Newton, Masachusetts, near Boston. I prefer to go west from here, rather than north or south, but anywhere close will work.
Chas
www.bubbledrome.com
Thank you
Old 04-23-2004, 09:08 AM   #8
Patriotic
Chuck's Avatar
Images: 99
Chas
Well, Marty's is probably about 45 minutes or so south. I don't think there's much here around the city in terms of RV dealers...slim picken's in general. most seem to be down on the south shore, for whatever reason. there's nothing up my way. a couple in Southern NH. I think others are out west, but beyond the Worcester area.
technically, any hvac tech could do what you want, but I don't know if I'd want them up on the curved roof of my airstream. and they might not want to do it, either.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-23-2004, 09:37 AM   #9
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
IF you can find a HVAC guy to do it you will be many $$ ahead of a RV place when it come to the roof AC. All they want to do is R&R it. Sell you a new one. IF it is an Armstrong, and working, but not cold enough I would search for someone to get it fixed. If it is a Coleman I would R&R it. The Coleman's do not last the way the Armstrong's do.
The Armstrong's use normal AC parts.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-23-2004, 10:53 AM   #10
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Chasgould,
Are you talking engine A/C or rooftop A/C?
The engine A/C ( dash air) is easily converted. It takes a complete evac, then a special A/C lubricant along with different fittings. This makes it ready to receive R134. Some vehicles requuire chages of temperature switches and/or compressor cutout switches.
They used to make a big deal out of it, and make you change compressors and driers, hoses etc., as well as every single o-ring in the system. That was hype to make more money on the regulation on the manufacturer's part.
I had 3 cars converted, and it was less than $ 100.00 each time, including temp and compressor switches with different values. ( 2 Mercedes cars, and a Dodge van with dual A/C) I have since sold the Dodge, but the 2 others still work great.
The rooftop a/c is another story. I imagine i too, could be easily converted to R134 if it indeed uses R12.
Uwe
www.area63productions.com
Old 04-23-2004, 02:31 PM   #11
Profile:
Hi Terry,
Thanks for the input on my Univolt/coach battery problem. Give that man a Kupie doll. He had the correct answer. It was a bad ground to the coach battery, and running an ancillary ground did solve the problem in that the 12 volt accessories now all work as long as the unit is lugged into 110 volt city power. Should the 12 volt lights and accessories run off of the coach battery without 110 volt city power. If so, is ther a switch to activate that?
Chas
www.bubbledrome.com
Thank you
Old 04-23-2004, 07:29 PM   #12
Well-Preserved
Hi Terry,
Chas
Sounds like you also have a bad connection from the batteries to the coaches' 12v system. You now have lights when plugged into shore power, that takes away a lot of guess work. Have you checked your batteries?
It sounds like you are close to taming the monster, keep checking, there is only so much wire between the battery and the electrical distribution panel.
Old 04-23-2004, 07:48 PM   #13
jjonesnc's Avatar
Profile:  Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
Chas,
Due to the age of you coach I would highly reccomend replacing the reciever/dryer on your dash ac when you have the retrofit done. I have done Motorhomes of the same age as yours, some needed entirely new systems and some were ok but few. ALL of them had reciever/dryers that were as heavy as a brick
-Jason
jjonesnc is offline   Reply With Quote
Old 04-24-2004, 05:40 AM   #14
Profile:
I guess that you mean that the 12 volt stuff should work, even when not plugged into 110 power. So, are you suggesting that I runanother test lead from the positive terminal of the coach battery to the positive outlet of the UNIVOLT, or to somewhere on the coach wiring? But where? If it were not hooked to the UNIVOLT< I would not get 14 volts at the batter terminals, so I suspect that you are correct, that it needs to be tied into the coach somewhere. Would a bad ammeter at the control panel cause this lack of connections?
I am taming this beast, but I prefer to move on to other problems! Thanks for the help.
Chas
www.bubbledrome.com
Thank you
Univolt common problem 71tradewind 1970-79 Tradewind 19 09-04-2007 06:19 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 11:08 AM
Univolt question overlander76 Electrical - Systems, Generators, Batteries & Solar 12 07-08-2003 02:10 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
