Old 09-13-2012, 09:10 AM   #1
1966 22' Safari
Central Point , Oregon
Univolt question
This is my first post in a long time. My Univolt quit humming. I am trying to sort it out. Will 110 power still work when plugged in if my Univolt is toast?
Thanks in advance
Mark
cppilot is offline   Reply With Quote
Old 09-13-2012, 09:15 AM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
It should.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-13-2012, 09:40 AM   #3
1966 22' Safari
Thanks, I just checked and your right. I do have power to the outlets, but not power to the battery from the Univolt. Also no humming. Does this mean that the univolt is bad?
Old 09-13-2012, 09:43 AM   #4
1966 22' Safari
Thanks Skater, will I have any issues if I continue to use the Univolt to run the refer until I get a new charger/converter?
Old 09-13-2012, 09:50 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you checked the circuit breakers? The one that powers the Univolt may be tripped.
Old 09-13-2012, 09:54 AM   #6
Ottawa , ON
Barring Twinkie's suggestion...?
"It's dead, Jim."
Old 09-13-2012, 09:56 AM   #7
Ottawa , ON
ps: if your TT is a '66 model, I wonder if your refer uses 12 volts at all? If it does, and the refer is still running, then the Univolt ain't dead.
If the refer is original, I am fairly certain that it doesn't require 12V, but if I am wrong, there will surely be someone to correct come along right smartly.
Old 09-13-2012, 10:52 AM   #8
1966 22' Safari
Thanks to everyone, I did more trouble shooting and I believe the UV is dead. All breakers are fine, power to the UV, just no power out to the battery. Time for a Inteli-Power.
Old 09-13-2012, 02:18 PM   #9
1966 22' Safari
Can I replace my 30 amp Univolt with the inteli-power PD9245c. Would there be any issues going 45 amp from 30 amp.
Old 09-13-2012, 02:24 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
No, you'll be fine. It would be a good choice.
Vaughan
Old 09-13-2012, 03:56 PM   #11
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The 45 amps will just give you more flexibility.
But, now is the time to think about making other changes to your 12 v system such as more battery power and/or AGM batteries. It would be a good idea at this point to make sure you have the best compatability match between charger and batteries.
A good source for advice is Randy at Best Converter.
Old 09-13-2012, 10:07 PM   #12
1966 22' Safari
Thanks for all the great information.
