Old 07-22-2006, 08:48 AM   #1
2003 34' Classic S/O
PORTSMOUTH , Virginia
Univolt Problem?
34' 2003 Airstream. Do Not Ha 12 Volt Or 110 Response. Checked Circuit Brakers. What Next? If It Is The Univolt, Are There Other Products To Look For?
STERELLIE is offline   Reply With Quote
Old 07-22-2006, 09:07 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
are you saying you have no 120 volt power in the trailer at all?
john
you call them ferrets, i call them weasels.
Old 07-22-2006, 11:00 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Your '03 does not have a Univolt. It does have a converter, but it will be the modern switch mode electronic type. If you don't have ANY power in the trailer, check the 120 VAC from the source (plug) inward to the trailer and verify the voltage at every step. That includes the supply breakers, the plug and cord set, the plug into the trailer, etc. You should find a problem along the line somewhere.
Report back and let us know what you find.
« Gfci | Top | Gfci »
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 11:05 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 11:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
