That's Odd
You might want to disconnect the Univolt from the DC output.
Try powering up the Univolt again see if it shuts down the DC with it disconnected from the battery system. If the battery alone runs everything without shutting down, check the output voltage of the Univolt, I think you will find it is 0Vdc.
If this is true the best thing is to remove it and place it in a trash bin.
It is not worth repairing. Replacements can be had for less than a reputable shop would charge to repair the old one, and you would still have an old Univolt.
Good Luck
That's my $0.02
Peace
Gary
