Old 04-15-2003, 05:04 AM   #15
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Anvils are cheap, it's the darn shipping that gets you!!! Anvil $1700, shipping, $4000.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-15-2003, 05:11 AM   #16
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Dropping it on your your enemy, pricelesss
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-16-2003, 01:38 PM   #17
WayWard Wind's Avatar
2004 25' Safari
yep ! Living in the land of milk & honey, frozen septic systems & water lines ( not ours happy to say ) & one fish. we are 25 miles North of Brainerd, in Breezy Point. You know the Viking would have won the Super Bowl against Kansas years ago, but several of the Vikes key players were suspended for taking an illegal substance. Seems the league inspectors were in the locker room before the game & smelled what they thought was an illegal product. Lutefish & ruggabagas--After the game they discovered that it was some dirty soxs & jock straps. Anyway we were robbed of glory! If you should ever come up this way stop by ---bring the anvil & stump & we can have a beer & discuss the situtation.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-18-2003, 08:20 PM   #18
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
update
installed the unit today, replaced the rubber bushings that mounted the transformer. seemed to quiet it down some.
here it is in it's new home humming away. we pulled the oven to make it easy to get at.
john
Name:	reinstalled univolt 2.jpg
Old 04-18-2003, 08:26 PM   #19
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
out with the old
here is the deceased unit, found no output from the transformer to the diodes. (no wonder it didn't make much noise! just a very low hum, quite un univolt like!)
if it is not rebuilt we will save it for a donor unit just incase frankenverter needs parts.
once again, THANX CHAS!!!!!
john
Name:	the deceased.jpg
Old 04-19-2003, 12:57 PM   #20
79 SLY
trumpwer's Avatar
Fairview , Montana
Images: 46
Unhappy nervous.
Now you guys got me nervous. The book says I can leave the trailer plugged into 120 volt, the univolt maintains battery, then fades off. Is that going to "cook my batterys"? If so, should I unhook the battery when I am hooked to 120 for a couple days?
The Trumpowers
1979 SLY 31'
1979 GMC 4 door with s/c camper shell
trumpwer is offline   Reply With Quote
Old 04-19-2003, 01:26 PM   #21
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Cool don't be
trumpower
don't get too nervous, most of went on in this tread about unpluging is just tounge in cheek.
the way the capacitors are wired to the transformer creates a ferroresonate circuit.
simply put, it is somewhat self limiting as regards to charging current.
primative, yes! when compared to what is available today.
plugged in for a couple of days or longer will most likely be o.k.
just remember to check the water level in your battery cells regularly. i check mine once a month (i have a magnatec in my excella) you may want to check more often until you get a feeling for how much water you WILL need to add.
most people unplug the older univolts so they can have a normal conversation or sleep at night.
john
Old 04-19-2003, 05:05 PM   #22
want310's Avatar
it's not a univolt BUT
My converter is a Litton Triad-Utrad ....so it says
It hums for 10 sec then pops the house circuit breaker
The white wire mentioned on the end plate isn't connected to anything
The unit is sealed by rivets so I'm assuming it's not meant to be serviced by a novice .....that means me
It doesn't have internal fuses shown in pics of a Univolt
I'm enclosing a top veiw and the end w/ specs
Is it scrap?????I could use some help
http://handicappedtravelclub.com/
want310 is offline   Reply With Quote
Old 04-19-2003, 06:29 PM   #23
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Question what white wire?
310,
what white wire are you referring to?
there should be two, one to ground the 12v circuit, the other is the neutral on the 120v side.
i see in the pic the white wire on yours sez power on, that could be for an indicator light.
john
Old 04-19-2003, 08:12 PM   #24
want310's Avatar
John,
The 120 & 12 volt wires are no problem.
The white wire is apprx 18 ga. I think you are correct that it would be for a indicator light
How about the tripping the breaker problem? I feel the unit has seen it's last days. Would it be wise to have it repaired?
Steve
Old 04-19-2003, 08:28 PM   #25
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i think by the time you pay someone to look at it you would be better to get a new one.
there is a 30 amp unit for sale on ebay, here you could use that for a basis on what a replacement might cost.
however, there is still hope. the 74 excella that the unit in this post was installed has the univolt powered on the GFI circuit. it shares about 4 to 5 other outlets. when we went to power it up we found the GFI tripped from the exterior outlet being damp.
have you tried the univolt on a seperate circuit?
if it is junk toss it, but you might kick yerself if a new inverter snapped the breaker too!
can't hurt to try it plugged into a different source, just be careful!
john
Old 04-20-2003, 07:42 AM   #26
want310's Avatar
Thanks John....I removed it from the trailer and tried several outlets and...... POP.....I'll s...can it
I checked out ebay and there is a Iota unit.......know anything about these??
....Steve
The Argost part on ebay looks like a fuse box only.....
There is no transformer in it
My fuse box is mounted on the wall and has the same configuration of fuses
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Where to get new or recon. Univolt 5 smashtin Electrical - Systems, Generators, Batteries & Solar 1 07-30-2003 09:09 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 11:08 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
