Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-03-2004, 06:23 PM   #1
Profile:
Univolt - its warm but humming!
I am ready to have a 13,500 BTU ac added to my 68 GT. Is the Univolt ready to handle the load. I think it is 30 amp/ I noticed it was warm, not hot, is that normal? I would guess yes.
Thanks- Bryan
Bryanhu is offline   Reply With Quote
Old 04-03-2004, 06:28 PM   #2
jjonesnc's Avatar
Profile:  Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
The Univolt is a 12 volt power supply/ battery charger seperate from the 120 volt system.
warm and humming are common AND DEAD/LEAKING CAPACITORS ARE COMMON! I just put new caps in my 1980 Univolt with excellent results.
-Jason
jjonesnc is offline   Reply With Quote
Old 04-03-2004, 06:30 PM   #3
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Bryan,
The univolt only converts regular household electricity to 12 volt for the lights and fans, it also recharges the battery(s). Your AirConditioner will be hooked up to the circuit breaker panel where the 120 volt house power comes in. So you are good to go as long as the correct sized breaker is installed. BTW my Uni-volt hums too, one of these days it will be replaced with a newer quieter unit.
Aaron
WBCCI #2449 AIR #2495
wahoonc is online now   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
warm outlets markus Electrical - Systems, Generators, Batteries & Solar 5 11-29-2003 04:06 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 11:08 AM
Univolt stop running and start later brunoffrance Electrical - Systems, Generators, Batteries & Solar 6 07-04-2003 12:33 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
