Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-01-2004, 07:27 PM   #1
Wagon Master
Profile:
Question Univolt is it working??
1968 univolt: Took the cover off, blew all the dust out, put it back together and hooked it back up. I put a multimeter on it and it said 11.17 volts. Ove hour later it read 11.40, 2 hours later it was at 11.7. I figured this is the battery voltage, right? So how can you run the 12v stuff in the trailer if it takes so long to charge? The readings were with no lights on or anything else 12v. Once the batterys are at full charge (13.8v) does it make more power to run the 12v stuff or is this not working right. I have never used a Univolt before. It makes a buzzing sound when on, and there is some kind of smell that you can smell when you re-enter the trailer. It may just be "old smell" as the last owner parked it from th etime they bought it and the owner before them had it parked for a number of years also.
HELP
Igor
Igor68 is offline   Reply With Quote
Old 12-01-2004, 08:38 PM   #2
RichardT's Avatar
Profile:
Take the battery out for a minute to really test it, it can run without the battery indefinitly , but it is best to have a battery in.
Check it under load by turning on some lights.
RichardT is offline   Reply With Quote
Old 12-02-2004, 04:46 AM   #3
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
igor
what do you have for a voltmeter?
some can be off by as much as a couple of volts. a quick test is to turn on some lights with a battery installed, then turn the univolt on/off see if the lights get brighter when you turn it on.
it is good you are seeing and increase over time. your voltmeter just might be slightly off.
because univolts are ferroresonate chargers they need the battery in the circuit to operate properly and will actually show a higher voltage with a battery connected vs. a no load reading without a battery in the circuit.
john
you call them ferrets, i call them weasels.
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
