Old 04-09-2014, 08:58 AM   #1
1976 31' Sovereign
ompah , Ontario
Univolt buzzing . Can I override since don't need battery?
I'm just starting on reno of 76 sovereign.Can live without battery power but do I need a battery for transit to location or just system integrity once its located ? Thanks Pete
fast fredy is offline   Reply With Quote
Old 04-09-2014, 09:22 AM   #2
1974 Argosy 20
Kooskia , Idaho
You need a battery to operate the brakes via the break away switch while traveling. Otherwise one is not really needed to sit in one place. Even the old buzz box Univolt, if operating still, will do that.
Old 04-09-2014, 09:48 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
With the univolt disconnected your battery will not last very long while using the 12 volt lights in the trailer.
The buzzing may be the plates in the transformer are starting to delaminate
You want to replace the univolt with a more modern charging system.
2004 Excursion 4x4
Manual Override on Electric Dump Valves Supercatspjs Sprinter and B-van Forum 58 08-02-2014 03:05 PM
If I dont need a battery power can dispense with univolt? can I dispense fast fredy Batteries, Univolts, Converters & Inverters 7 04-14-2014 03:46 PM
Does this jack have a manual override? NicheVintage Jacks, Stabilizers, Lifting and Leveling 2 01-16-2010 11:00 PM
Electric Tongue Jack Manual Override overlander64 Jacks, Stabilizers, Lifting and Leveling 10 05-07-2009 09:22 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
